[postgis-users] postgis 2.0 and postgist 2.1 compatibility issues
Paragon Corporation
lr at pcorp.us
Thu Dec 12 18:26:32 PST 2013
Marty,
Which version of PostGIS 2.1 are you running 2.1.0 or 2.1.1?
Do a: SELECT postgis_full_version();
Your example of two seemingly equivalent table creations resulting in
different results is a bit troubling.
When you say extent seems to be an issue but ST_Extent is not, I am assuming
you are confirming this in QGIS or other software. The only thing I could
think of
Is that the ST_EstimatedExtent answer might be different and I think various
GIS software use that for extent estimation.
Can you check the answer of ST_EstimatedExtent in both problem and
non-problem case
http://postgis.net/docs/manual-2.1/ST_Estimated_Extent.html
If they are different, try running
Vacuum analyze verbose new_roads2;
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Marty O'Neill II
Sent: Thursday, December 12, 2013 6:28 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] postgis 2.0 and postgist 2.1 compatibility issues
I am running postgresql 9.1 with postgis 2.0 in Windows 7. After creating a
dump from the database, I tried to restore on a machine running Ubuntu with
postgresql 9.3 and postgis 2.1. However, the spatial extent is incorrect
when viewed in QuantumGIS and in other custom GIS software. The spatial
extent in QuantumGIS and our software seems to include a 0.0 coordinate.
However, running ST_Extent on one of the problem tables does not reveal any
such issues. There are no empty records. We have tried PostGIS_DropBBox(),
Populate_Geometry_Columns(), and reindexing the tables. We have tried
generating the dump and restoring it both from pgAdmin and using the command
line. The projections are correctly set on all records, and the tables have
valid entries in the geometry_columns view.
Let roads be one of the problematic tables. If we execute the following
query
SELECT * INTO new_roads FROM roads;
... then the problem with the spatial extent does not exist on table
new_roads. However, if we execute the query
SELECT * INTO new_roads2 FROM (SELECT * FROM roads) AS temp;
.. then the problem continues to exist on table new_roads2
We suspect that the issue may be due to compatibility issues between PostGIS
2.0 and 2.1. Does anybody have any ideas on why this is happening?
Thank you,
Marty
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
