[postgis-users] How can I create a point at a known distance & bearing from a point in Postgis?
David Rowley dgrowleyml at gmail.com
Sat Dec 14 21:08:37 PST 2013
On Sun, Dec 15, 2013 at 2:52 PM, Brent Wood <pcreso at pcreso.com> wrote:
> Hi,
> I have a dataset with start & end points that we are represtnting as
> linestrings. Many records do not have endpoints - so we are takimg the
> median bearling for comparable startpoints & creating an arbitrary endpoint.
> While it is easy to get a bearing for a known endpoint with ST_Azimuth(),
> is there a simple way in Postgis to get the point at a defined distance &
> bearing? I've perused the docs & nothing jumped out as an obvious solution.
Sounds like you need ST_Project()
Regards
David Rowley
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131215/0a33396d/attachment.html>
