[postgis-users] How can I create a point at a known distance & bearing from a point in Postgis?
Brent Wood
pcreso at pcreso.com
Sat Dec 14 17:52:46 PST 2013
I
have a dataset with start & end points that we are represtnting as
linestrings. Many records do not have endpoints - so we are takimg the
median bearling for comparable startpoints & creating an arbitrary
endpoint.
While it is easy to get a bearing for a known endpoint
with ST_Azimuth(), is there a simple way in Postgis to get the point at a
defined distance & bearing? I've perused the docs & nothing
jumped out as an obvious solution.
Thanks,
Brent Wood
From: Simon Greener <simon at spatialdbadvisor.com>
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Sent: Thursday, April 11, 2013 6:57 PM
Subject: Re: [postgis-users] Finding closet intersect point along direction of line
Adrian,
That's excellent.
regards
Simon
On Thu, 11 Apr 2013 16:51:14 +1000, <adrian.kitchingman at dse.vic.gov.au> wrote:
Thanks for the code Simon. After a few
tweaks I got it working perfectly in PostGIS2.
>Here's the updated code.
>Adrian
>CREATE OR REPLACE FUNCTION ST_Extend(eje_
geometry, bound_ geometry)
>RETURNS geometry
>AS $$
>-- Use Case: I need to "extend"
a linestring in another one. The new linestring must be
>-- obtained such as their new extremes
are the intersection of it with a
>-- polygon that contains it. The original
linestring is composed of only a
>-- linear segment.
>-- version: alfa , by Julio A. Galindo,
April 17, 2007: juliogalindoq at gmail.com
>DECLARE
> b_ geometry = st_boundary(bound_);
> dist float;
> max_dist float
= 0;
> n_points int;
> pto_1 geometry;
> pto_2 geometry;
> first_pto geometry;
> last_pto geometry;
> u_1 float;
> u_2 float;
> norm float;
> result text = 'LINESTRING(';
>BEGIN
> IF st_GeometryType(eje_)
NOT LIKE 'ST_LineString' OR
> st_GeometryType(bound_)
NOT LIKE 'ST_Polygon' THEN
> RETURN
NULL;
> END IF;
> -- First Search
how far is the boundary: (worst case)
> pto_1 := st_StartPoint(eje_);
> pto_2 := st_EndPoint(eje_);
> FOR i IN 1..st_NumPoints(b_)-1
LOOP
> dist
:= st_distance(st_PointN(b_,i),pto_1);
> IF
dist > max_dist THEN max_dist := dist; --END IF;
max_dist := dist;
> END
IF;
> dist
:= st_distance(st_PointN(b_,i),pto_2);
> IF
max_dist := dist;
> END
IF;
> END LOOP;
> -- Now extent the
linestring:
> pto_2 := st_PointN(eje_,2);
> u_1 := st_X(pto_2)-st_X(pto_1);
> u_2 := st_Y(pto_2)-st_Y(pto_1);
> norm := sqrt(u_1^2
+ u_2^2);
> first_pto := st_MakePoint(st_X(pto_1)-u_1/norm*dist,st_Y(pto_1)-u_2/norm*dist);
> n_points := st_nPoints(eje_);
> IF n_points >
2 THEN
> pto_1
:= st_PointN(eje_,n_points-1);
> pto_2
:= st_PointN(eje_,n_points);
> u_1
> u_2
> norm
:= sqrt(u_1^2 + u_2^2);
> END IF;
> last_pto := st_MakePoint(st_X(pto_2)+u_1/norm*dist,st_Y(pto_2)+u_2/norm*dist);
> result :=
result || st_X(first_pto) || ' ' || st_Y(first_pto) || ',';
> FOR i IN 1..st_NumPoints(eje_)
LOOP
> result
:= result || st_X(st_PointN(eje_,i)) || ' ' || st_Y(st_PointN(eje_,i))
> END LOOP;
> result := result
|| st_X(last_pto) || ' ' || st_Y(last_pto) || ')';
> -- Find the final
Linestring:
> b_ := st_intersection(st_GeomFromText(result,st_SRID(eje_)),bound_);
> RETURN b_;
> END $$
> LANGUAGE plpgsql
> STABLE
> RETURNS NULL ON NULL INPUT;
>Notice:
>This email and any attachments may contain information that is
personal, confidential,
>legally privileged and/or copyright. No part of it
should be reproduced, adapted or communicated without the prior written consent
of the copyright owner.
>It is the responsibility of the recipient to check for and remove
viruses.
>If you have received this email in error, please notify the sender by return
email, delete it from your system and destroy any copies. You are not authorised
to use, communicate or rely on the information contained in this email.
>Please consider the environment before printing this email.
Holder of "2011 Oracle Spatial Excellence Award for Education and Research."
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
Email: simon at spatialdbadvisor.com
Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131214/79d83dd9/attachment.html>
