[postgis-users] help with the Union of 2 shp
Rémi Cura remi.cura at gmail.com
Mon Dec 16 05:38:22 PST 2013
And of course it is *a very bad idea* to try something without knowing if
it works on all your data !
You should try the complete solution on a small sample, then optimize your
queries, then use it on all your data...
Cheers,
Rémi-C
2013/12/16 Nicolas Ribot <nicolas.ribot at gmail.com>
> Hi,
> If you have a lot of data in your tables, it could be much faster to to a
> CREATE TABLE as SELECT... than doing an update on an existing table.
> Nicolas
> On 15 December 2013 23:48, J.Alejandro Martinez Linares <
> islanis at infomed.sld.cu> wrote:
>>  Hey all, i follow your answer Remi, but do this because your code come
>> to me late:
>> --part 1
>> DROP TABLE IF EXISTS all_lines;
>> CREATE TABLE all_lines AS
>> SELECT ST_ExteriorRing((ST_Dump(z.the_geom)).geom) AS the_geom
>> FROM public.rad_solar_global z
>> UNION ALL
>> SELECT ST_ExteriorRing((ST_Dump(r.the_geom)).geom) AS the_geom
>> FROM public.rad_solar_plano_inclinado r;
>> UPDATE all_lines SET the_geom=ST_SetSRID(the_geom,4326);
>> SELECT Populate_Geometry_Columns('public.all_lines'::regclass);
>> ALTER TABLE all_lines ADD column gid serial;
>> ALTER TABLE all_lines ADD PRIMARY KEY (gid);
>> --part 2
>> DROP TABLE IF EXISTS all_lines_MERGED;
>> CREATE TABLE all_lines_MERGED AS
>> (SELECT ST_LineMerge(k.the_geom) AS the_geom
>> FROM public.all_lines k);
>> UPDATE all_lines_MERGED SET the_geom=ST_SetSRID(the_geom,4326);
>> SELECT Populate_Geometry_Columns('public.all_lines_MERGED'::regclass);
>> ALTER TABLE all_lines_MERGED ADD column gid serial;
>> ALTER TABLE all_lines_MERGED ADD PRIMARY KEY (gid);
>> --part 3
>> DROP TABLE IF EXISTS rad_solar_directa_SPLITED;
>> CREATE TABLE rad_solar_directa_SPLITED AS
>> (SELECT ST_Split(b.the_geom,k.the_geom) AS the_geom
>> FROM public.rad_solar_directa b,public.all_lines_MERGED k);
>> UPDATE rad_solar_directa_SPLITED SET the_geom=ST_SetSRID(the_geom,4326);
>> SELECT
>> Populate_Geometry_Columns('public.rad_solar_directa_SPLITED'::regclass);
>> ALTER TABLE rad_solar_directa_SPLITED ADD column gid serial;
>> ALTER TABLE rad_solar_directa_SPLITED ADD PRIMARY KEY (gid);
>> --i just have made part 1,2  and am still in part 3, am there since 2
>> days ago, is there a way to know if this is working fine or if it fall in
>> an  unfinish error. am still in part 3, is that posible? help please.
>> Cheers,
>> Ale
>> El 14/12/13 17:19, Rémi Cura escribió:
>>         OK,
>>  with luck you won't have precision issues.
>>  (please note that the only good way to do this is to use
>> postgis_topology and faces.)
>>  So here is one idea to do it :
>>  table1 : first image, very big shape
>>  table 2 : second image, smal rectangular shape
>>  table 3 third image , mdium irregular shape
>>  1.) convert poly from table 1 and table 3 to linestring. (i called these
>> lines dumped_lines for the following)
>>  You can do it manually or use the function I wrote (beta)
>> https://github.com/Remi-C/PPPP_utilities/blob/master/postgis/rc_DumpLines.sql
>>  2.) split poly from table 2 by the dumped_lines from table 1 (
>> http://postgis.net/docs/ST_Split.html) . The result are polygons
>>  3.) Split the result from 2. by dumpl_lines from table 3. The result are
>> polygons.
>>  3. is what you want geometrically. I'll call it splited_polygons for the
>> following
>>  Now you want to get, for each splitted_polygons, the id of polygons of
>> table 1, and 3 which overlaps. You already have id from table 2 because you
>> can keep it during computing of  2. and 3.
>>  you can do it sequentially :
>>  SELECT DISTINCT ON (sp.geom) sp.geom, aray_agg(id) AS id_table1
>>  FROM splited_polygons AS sp, table_1
>>  WHERE ST_Overlaps(sp.geom, table_1.geom)=TRUE
>>  , then the same type of query on result, with table 3
>>  Cheers,
>> Rémi-C
>> 2013/12/12 <islanis at infomed.sld.cu>
>>> I want to create little pieces of multipolygons from these 3 shapes (A,B
>>> and C)=result , result with all the sections formed with the intersection
>>> from the 3 shapes together, come on tell me , do you understand now what i
>>> want
>>> thanks
>>>  no never mind am not offended, am trying that you understand Ok, here
>>>> are png of my 3 multipolygon shapes, what else do you need
>>>> "Rémi Cura" <remi.cura at gmail.com> escribió:
>>>>  Sorry I'm  not trying to offend you.
>>>>> For example in this thread
>>>>> https://groups.google.com/forum/#!topic/postgis-users/9pozIoUAZuI
>>>>> The asker posted an image to explain better.
>>>>> Cheers,
>>>>> Rémi-C
>>>>>  no is not dificult to understand, what ever you want i'll give , just
>>>>>> ask
>>>>>> what do you want to a better understanding. please i need it
>>>>>> I'm very sorry it is difficult to understand what you mean.
>>>>>>> Maybe with a real drawing and link here to it, or to some
>>>>>>> screenshots?
>>>>>>> Cheers,
>>>>>>> Rémi-C
>>>>>>> thanks for the quick answer Rémi, but, thats right thats one of
>>>>>>> answers,
>>>>>>>> but my idea was not complete,because there is a
>>>>>>>> 3rd shape, your answer works fine for the 1st and 2dn shapes, but
>>>>>>>> not
>>>>>>>> with
>>>>>>>> the 3rd, because the 3rd has not suares inside,
>>>>>>>> the 3rd shape have big triangles inside,the idea is that i need some
>>>>>>>> routine that merge or blend the spatial data and with it the
>>>>>>>> attributes
>>>>>>>> of respective data, i need some ideas for do that, and am working
>>>>>>>> on it,
>>>>>>>> but not sucess, please i need help, thanks for all.
>>>>>>>> 1-the first shapefile
>>>>>>>> __________________
>>>>>>>> |         1       |     shp=A
>>>>>>>> |_________________|
>>>>>>>> num of poligons=1
>>>>>>>> The one big country, this is a multipolygon shape
>>>>>>>> DATA=>dni01 numeric,dni02 numeric,dni03 numeric,
>>>>>>>>      dni04 numeric,dni05 numeric,dni06 numeric,
>>>>>>>>      dni07 numeric,dni08 numeric,dni09 numeric,
>>>>>>>>      dni10 numeric,dni11 numeric,dni12 numeric,
>>>>>>>>      dniann numeric,the_geom geometry
>>>>>>>> 2-and the second shapefile
>>>>>>>> __________________
>>>>>>>> |     2  |  2     |
>>>>>>>> |________|________|
>>>>>>>> |     2  |  2     |     shp=B
>>>>>>>> |________|________|
>>>>>>>> |     2  |  2     |
>>>>>>>> |________|________|
>>>>>>>> num of poligons = 6
>>>>>>>> The same country, but this time in little pieces, the states, this
>>>>>>>> is a
>>>>>>>> multipolygon shape too
>>>>>>>> 3-and the second shapefile
>>>>>>>> __________________
>>>>>>>> |   3    /        |     shp=C
>>>>>>>> |      /     4    |
>>>>>>>> |_____/___________|
>>>>>>>> num of poligons = 2
>>>>>>>> is a
>>>>>>>> and i want join the 2 shapes in only one shapefile getting something
>>>>>>>> like
>>>>>>>> this
>>>>>>>> ______________________________
>>>>>>>> |              |1,2,3  /      |
>>>>>>>> |    1,2,3     |      /1,2,4  |
>>>>>>>> |______________|____/_________|
>>>>>>>> |              |1,2/          |     shp=A and B
>>>>>>>> |              |,3/           |
>>>>>>>> |    1,2,3     | /     1,2,4  |
>>>>>>>> |______________/______________|
>>>>>>>> |    1,2,3  /1,|       1,2,4  |
>>>>>>>> |          /2,4|              |
>>>>>>>> |_________/____|______________|
>>>>>>>> num of poligons = 9
>>>>>>>> DATA=>dni01A numeric,dni02A numeric,dni03A numeric,dni04A numeric,
>>>>>>>>     dni05A numeric,dni06A numeric,dni07A numeric,dni08A numeric,
>>>>>>>>     dni09A numeric,dni10A numeric,dni11A numeric,dni12A numeric,
>>>>>>>>     dniannA numeric,dni01B numeric,dni02B numeric,dni03B numeric,
>>>>>>>>     dni04B numeric,dni05B numeric,dni06B numeric,dni07B numeric,
>>>>>>>>     dni08B numeric,dni09B numeric,dni10B numeric,dni11B numeric,
>>>>>>>>     dni12B numeric,dniannB numeric,dni01C numeric,dni02C numeric,
>>>>>>>>     dni03C numeric,dni04C numeric,dni05C numeric,dni06C numeric,
>>>>>>>>     dni07C numeric,dni08C numeric,dni09C numeric,dni10C numeric,
>>>>>>>>     dni11C numeric,dni12C numeric,dniannC numeric,the_geom geometry
>>>>>>>> Seems like If you want :
>>>>>>>>  for each little square, get the id of big square overlaping.
>>>>>>>>> If this is simply this, you don't need the "intersection" function,
>>>>>>>>> but only the "intersects" function :
>>>>>>>>> You could do something like this
>>>>>>>>> SELECT ss.id, bs.id , ss.geom
>>>>>>>>> FROM smal_square_table AS ss, big_square_table AS bs
>>>>>>>>> WHERE ST_Intersects(ss.geom,bs.geom)=TRUE
>>>>>>>>> Cheers,
>>>>>>>>> Rémi-C
>>>>>>>>> Hi,
>>>>>>>>>>  Try pg 21 of this: http://presentations.opengeo.
>>>>>>>>>>> org/2011_FOSS4G/postgis-power.pdf
>>>>>>>>>>> That will give you the metacode.
>>>>>>>>>>> Overlays. (he sighs.)  Be glad you only have 2 layers... .
>>>>>>>>>>> Best,
>>>>>>>>>>> Steve
>>>>>>>>>>> Hey steve thanks for the book is really good as a resume, but the
>>>>>>>>>>> only
>>>>>>>>>>>  apart that it have to do with my problem is the intersection of
>>>>>>>>>> 2
>>>>>>>>>> shapes
>>>>>>>>>> "SELECT
>>>>>>>>>> a.*, b.*,
>>>>>>>>>> ST_Intersection(a.geom, b.geom)
>>>>>>>>>> FROM
>>>>>>>>>> a, b
>>>>>>>>>> WHERE
>>>>>>>>>> ST_Intersects(a.geom, b.geom);"
>>>>>>>>>> but my problem  is different, i got as a mention 2 shapes with
>>>>>>>>>> the same
>>>>>>>>>> projection and place,
>>>>>>>>>> and are the same but one is from one study, and the other is from
>>>>>>>>>> other
>>>>>>>>>> stufy, but are the same
>>>>>>>>>> place and each one have data, the only things that they got
>>>>>>>>>> different
>>>>>>>>>> are
>>>>>>>>>> the size of the squares,the data they got and the
>>>>>>>>>> name of the columns are the same, but the values are different
>>>>>>>>>> cause
>>>>>>>>>> the
>>>>>>>>>> type of the study
>>>>>>>>>> ,there is one that have the squares more smaller that the other,
>>>>>>>>>> but i
>>>>>>>>>> dont want lose any data, i need that in the map it has seen like
>>>>>>>>>> the figure "A and B" but in the data each row got the values of A
>>>>>>>>>> and
>>>>>>>>>> the
>>>>>>>>>> values of B
>>>>>>>>>> __________________
>>>>>>>>>> |         1       |     shp=A
>>>>>>>>>> |_________________|
>>>>>>>>>> __________________
>>>>>>>>>> |     2  |  2     |
>>>>>>>>>> |________|________|
>>>>>>>>>> |     2  |  2     |     shp=B
>>>>>>>>>> |________|________|
>>>>>>>>>> |     2  |  2     |
>>>>>>>>>> |________|________|
>>>>>>>>>> this is
>>>>>>>>>> a
>>>>>>>>>> something
>>>>>>>>>> like
>>>>>>>>>> this
>>>>>>>>>> __________________
>>>>>>>>>> |    1,2 |   1,2  |
>>>>>>>>>> |________|________|
>>>>>>>>>> |    1,2 |   1,2  |     shp=A and B
>>>>>>>>>> |________|________|
>>>>>>>>>> |    1,2 |   1,2  |
>>>>>>>>>> |________|________|
>>>>>>>>>>     dni12B numeric,dniannB numeric,the_geom geometry
>>>>>>>>>> i think that this is posible to do with postgis, but i dont know
>>>>>>>>>> why,
>>>>>>>>>> am
>>>>>>>>>> looking in quantumGIS but i lose data cause the big suare overlap
>>>>>>>>>> the
>>>>>>>>>> little
>>>>>>>>>> ones and i lose data cause there is some places that i get NULL.
>>>>>>>>>> please help
>>>>>>>>>> thanks for all
>>>>>>>>>>> On Mon, Dec 9, 2013 at 11:03 AM, J.Alejandro Martinez Linares <
>>>>>>>>>>>>  Hi People, i need your help, let say that i have 2 shapefiles
>>>>>>>>>>>>  __________________
>>>>>>>>>>>>  |         1       |     shp=B
>>>>>>>>>>>>  |_________________|
>>>>>>>>>>>>  One big country, this is a multipolygon shape
>>>>>>>>>>>>  __________________
>>>>>>>>>>>>  |     2  |  2     |
>>>>>>>>>>>>  |________|________|
>>>>>>>>>>>>  |     2  |  2     |     shp=B
>>>>>>>>>>>>  |________|________|
>>>>>>>>>>>>  |     2  |  2     |
>>>>>>>>>>>>  |________|________|
>>>>>>>>>>>> this
>>>>>>>>>>>> is
>>>>>>>>>>>> a multipolygon shape too
>>>>>>>>>>>> something
>>>>>>>>>>>> like this
>>>>>>>>>>>>  __________________
>>>>>>>>>>>>  |    1,2 |   1,2  |
>>>>>>>>>>>>  |________|________|
>>>>>>>>>>>>  |________|________|
>>>>>>>>>>>>  |    1,2 |   1,2  |
>>>>>>>>>>>>  |________|________|
>>>>>>>>>>>>  i think that this is posible, please help me to get somthing
>>>>>>>>>>>> like
>>>>>>>>>>>> this i need it.
>>>>>>>>>>>>  Este mensaje le ha llegado mediante el servicio de correo
>>>>>>>>>>>> electronico
>>>>>>>>>>>> que ofrece Infomed para respaldar el cumplimiento de las
>>>>>>>>>>>> misiones del
>>>>>>>>>>>> Sistema Nacional de Salud. La persona que envia este correo
>>>>>>>>>>>> asume el
>>>>>>>>>>>> compromiso de usar el servicio a tales fines y cumplir con las
>>>>>>>>>>>> regulaciones
>>>>>>>>>>>> establecidas
>>>>>>>>>>>>  Infomed: http://www.sld.cu/
>>>>>>>>>>>>  _______________________________________________
>>>>>>>>>>>>  postgis-users mailing list
>>>>>>>>>>>>  postgis-users at lists.osgeo.org
>>>>>>>>>>>>  http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>>>>>>> This message was sent using IMP, the Internet Messaging Program.
>>>>>>>>>> electronico
>>>>>>>>>> que
>>>>>>>>>> ofrece Infomed para respaldar el cumplimiento de las misiones del
>>>>>>>>>> Sistema
>>>>>>>>>> Nacional de Salud. La persona que envia este correo asume el
>>>>>>>>>> compromiso
>>>>>>>>>> de
>>>>>>>>>> usar el servicio a tales fines y cumplir con las regulaciones
>>>>>>>>>> establecidas
>>>>>>>> electronico que
>>>>>>>> Sistema
>>>>>>>> compromiso
>>>>>>>> de
>>>>>>>> establecidas
>>>>>> Este mensaje le ha llegado mediante el servicio de correo electronico
>>>>>> que
>>>>>> Sistema
>>>>>> compromiso de
>>>>>> establecidas
>>>> que ofrece Infomed para respaldar el cumplimiento de las misiones del
>>>> Sistema Nacional de Salud. La persona que envia este correo asume el
>>>> compromiso de usar el servicio a tales fines y cumplir con las regulaciones
>>>> establecidas
>>> establecidas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131216/e2651e37/attachment.html>
