[postgis-users] GeometryCollection with GEOMETRYCOLLECTIONM, POINTM etc.. value in constructor.
Baris Ergun barisergun75 at gmail.com
Wed Dec 18 00:20:20 PST 2013
Hello
I create a GeometryCollection as below
GeometryCollection coll = new GeometryCollection(
                            "SRID=-1;GEOMETRYCOLLECTIONM(POINTM(10 10
100),LINESTRINGM(0 50 100, 100 50 100),POLYGONM((25 25 100,75 25 100,75 75
100,25 75 100,25 25 100),(45 45 100,55 45 100,55 55 100,45 55 100,45 45
100)))"));
when I reprint the coll.toString() I see that my geom string is changed to
below :
"SRID=-1;GEOMETRYCOLLECTIONM(POINT(10 10 100),LINESTRING(0 50 100, 100 50
100),POLYGON((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45
100,55 45 100,55 55 100,45 55 100,45 45 100)))"
As you can see GEOMETRYCOLLECTIONM is preserved but POINTM LINESTRINGM and
POLYGONM is changed to POINT LINESTRING and POLYGON . And because of this I
get cannot mix dimensionality when I am trying to insert this geom to
database.
I have tried this with postgis jdbc driver 1.1.5; 1.3.3 and 2.0.1 versions.
This is a test written in datanucleus orm for geospatial extensions and the
test is run against the below table (create script) in postgresql db.
CREATE TABLE public.samplepggeometrycollectionm
  samplepggeometrycollectionm_id integer NOT NULL DEFAULT
nextval('samplepggeometrycollectionm_samplepggeometrycollectionm_id_seq'::regclass),
  geom geometry(GeometryCollectionM),
  id bigint NOT NULL,
  name character varying(255),
  CONSTRAINT samplepggeometrycollectionm_pkey PRIMARY KEY
(samplepggeometrycollectionm_id)
WITH (
  OIDS=FALSE
ALTER TABLE public.samplepggeometrycollectionm
  OWNER TO postgres;
Awaiting ur suggestions.
Baris
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131218/b76a5d01/attachment.html>
