[postgis-users] GeometryCollection with GEOMETRYCOLLECTIONM, POINTM etc.. value in constructor.
Rémi Cura
remi.cura at gmail.com
Wed Dec 18 00:35:32 PST 2013
Hey,
using this in sql :
SELECT ST_AsText(ST_GeomFromText(
'GEOMETRYCOLLECTIONM(
POINTM(10 10 100),
LINESTRINGM(0 50 100, 100 50 100),
POLYGONM((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45 100,55
45 100,55 55 100,45 55 100,45 45 100))
It gives you the expected output.
I would guess it is the java function you are using that is faulty (the
geometrycollection constructer).
Cheers,
Rémi-C
2013/12/18 Baris Ergun <barisergun75 at gmail.com>
> Hello
> I create a GeometryCollection as below
> GeometryCollection coll = new GeometryCollection(
> "SRID=-1;GEOMETRYCOLLECTIONM(POINTM(10 10
> 100),LINESTRINGM(0 50 100, 100 50 100),POLYGONM((25 25 100,75 25 100,75 75
> 100,25 75 100,25 25 100),(45 45 100,55 45 100,55 55 100,45 55 100,45 45
> 100)))"));
> when I reprint the coll.toString() I see that my geom string is changed to
> below :
> "SRID=-1;GEOMETRYCOLLECTIONM(POINT(10 10 100),LINESTRING(0 50 100, 100 50
> 100),POLYGON((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45
> 100,55 45 100,55 55 100,45 55 100,45 45 100)))"
> As you can see GEOMETRYCOLLECTIONM is preserved but POINTM LINESTRINGM and
> POLYGONM is changed to POINT LINESTRING and POLYGON . And because of this I
> get cannot mix dimensionality when I am trying to insert this geom to
> database.
> I have tried this with postgis jdbc driver 1.1.5; 1.3.3 and 2.0.1
> versions.
> This is a test written in datanucleus orm for geospatial extensions and
> the test is run against the below table (create script) in postgresql db.
> CREATE TABLE public.samplepggeometrycollectionm
> samplepggeometrycollectionm_id integer NOT NULL DEFAULT
> nextval('samplepggeometrycollectionm_samplepggeometrycollectionm_id_seq'::regclass),
> geom geometry(GeometryCollectionM),
> id bigint NOT NULL,
> name character varying(255),
> CONSTRAINT samplepggeometrycollectionm_pkey PRIMARY KEY
> (samplepggeometrycollectionm_id)
> WITH (
> OIDS=FALSE
> ALTER TABLE public.samplepggeometrycollectionm
> OWNER TO postgres;
> Awaiting ur suggestions.
> Baris
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131218/f73ddb17/attachment.html>
