[postgis-users] raster with pixel < map unit
Rémi Cura remi.cura at gmail.com
Wed Dec 18 08:13:23 PST 2013
Ok I think I get it :
the width are in pixel and not in map unit.
Cheers,
Rémi-C
2013/12/18 Rémi Cura <remi.cura at gmail.com>
> Hey list,
> again noob question.
> It seems impossible to create an empty raster with less than one scale
> (takes integer !).
> Now when I want to update the scale, the number of pixel is not updated :
> Is it normal/what should I do?
> Cheers,
> Rémi-C
> DROP TABLE IF EXISTS patch_to_raster;
> CREATE TABLE patch_to_raster(rid serial primary key, rast raster);
> --delete  from patch_to_raster
> INSERT INTO patch_to_raster (rast) VALUES (
>  ST_MakeEmptyRaster(
> 1
> ,1
> ,upperleftx:=0
>  ,upperlefty:=0
> ,scalex:=1
> , scaley:=1
> , skewx:=0
>  ,skewy:=0
> --, srid:=932011
> ) --srid of translated lambert 93 to match laser referential
> UPDATE patch_to_raster SET rast = ST_SetScale(rast,0.02,0.02)
> FROM
> SELECT ST_SetScale(rast,0.02,0.02)
>  FROM patch_to_raster;
>  SELECT ST_Summary(rast)
> --Raster of 1x1 pixels has 0 bands and extent of BOX(0 0,0.02 0.02)
> Thanks,
> Rémi-C
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131218/26f972ba/attachment.html>
