[postgis-users] GeometryCollection with GEOMETRYCOLLECTIONM, POINTM etc.. value in constructor.
Baris Ergun
barisergun75 at gmail.com
Thu Dec 26 14:08:32 PST 2013
Hi Paul;
I have opened http://trac.osgeo.org/postgis/ticket/2588 and added the patch
fix there. Please review it and find the reasonings in comments in the
issue.
I would like to also correct errors and warnings on pom.xml of jdbc driver
this week.
Cheers.
On 23 December 2013 19:30, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> We need patches for Java issues as we have no active JDBC/Java maintainers
> ATM.
> P.
> On Sat, Dec 21, 2013 at 11:31 AM, Baris Ergun <barisergun75 at gmail.com>
> wrote:
> > I have tested the issue with latest snapshot 2.1.0SVN for jdbc driver.
> The
> > GeometryCollection still cannot parse the String value correctly. There
> is a
> > similar issue in postgis extension source codes.
> > http://trac.osgeo.org/postgis/ticket/724
> > So with the Java based jdbc codes it looks like we hit the same case. If
> I
> > could report this as a bug to trac I would do it right away but I dont
> have
> > access to there.
> > On 21 December 2013 11:57, Baris Ergun <barisergun75 at gmail.com> wrote:
> >> Hi Remi;
> >> Who should I get in touch about this issue related to
> >> org.postgis.GeometryCollection constructor in postgis jdbc driver.
> >> Thanks.
> >> On 18 December 2013 10:53, Baris Ergun <barisergun75 at gmail.com> wrote:
> >>> Exactly correct. I also tried to tell that the problem was originated
> >>> from org.postgis.GeometryCollection constructor. So I posted to here to
> >>> understand why constructor was behaving like this. This constructor is
> in
> >>> postgis-jdbc.jar . Anyone knowing about this problem on the
> >>> org.postgis.GeometryCollection constructor?
> >>> On 18 December 2013 10:35, Rémi Cura <remi.cura at gmail.com> wrote:
> >>>> Hey,
> >>>> using this in sql :
> >>>> SELECT ST_AsText(ST_GeomFromText(
> >>>> 'GEOMETRYCOLLECTIONM(
> >>>> POINTM(10 10 100),
> >>>> LINESTRINGM(0 50 100, 100 50 100),
> >>>> POLYGONM((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45
> >>>> 100,55 45 100,55 55 100,45 55 100,45 45 100))
> >>>> It gives you the expected output.
> >>>> I would guess it is the java function you are using that is faulty
> (the
> >>>> geometrycollection constructer).
> >>>> Cheers,
> >>>> Rémi-C
> >>>> 2013/12/18 Baris Ergun <barisergun75 at gmail.com>
> >>>>> Hello
> >>>>> I create a GeometryCollection as below
> >>>>> GeometryCollection coll = new GeometryCollection(
> >>>>> "SRID=-1;GEOMETRYCOLLECTIONM(POINTM(10 10
> >>>>> 100),LINESTRINGM(0 50 100, 100 50 100),POLYGONM((25 25 100,75 25
> 100,75 75
> >>>>> 100,25 75 100,25 25 100),(45 45 100,55 45 100,55 55 100,45 55 100,45
> 45
> >>>>> 100)))"));
> >>>>> when I reprint the coll.toString() I see that my geom string is
> changed
> >>>>> to below :
> >>>>> "SRID=-1;GEOMETRYCOLLECTIONM(POINT(10 10 100),LINESTRING(0 50 100,
> 100
> >>>>> 50 100),POLYGON((25 25 100,75 25 100,75 75 100,25 75 100,25 25
> 100),(45 45
> >>>>> 100,55 45 100,55 55 100,45 55 100,45 45 100)))"
> >>>>> As you can see GEOMETRYCOLLECTIONM is preserved but POINTM
> LINESTRINGM
> >>>>> and POLYGONM is changed to POINT LINESTRING and POLYGON . And
> because of
> >>>>> this I get cannot mix dimensionality when I am trying to insert this
> geom to
> >>>>> database.
> >>>>> I have tried this with postgis jdbc driver 1.1.5; 1.3.3 and 2.0.1
> >>>>> versions.
> >>>>> This is a test written in datanucleus orm for geospatial extensions
> and
> >>>>> the test is run against the below table (create script) in
> postgresql db.
> >>>>> CREATE TABLE public.samplepggeometrycollectionm
> >>>>> samplepggeometrycollectionm_id integer NOT NULL DEFAULT
> nextval('samplepggeometrycollectionm_samplepggeometrycollectionm_id_seq'::regclass),
> >>>>> geom geometry(GeometryCollectionM),
> >>>>> id bigint NOT NULL,
> >>>>> name character varying(255),
> >>>>> CONSTRAINT samplepggeometrycollectionm_pkey PRIMARY KEY
> >>>>> (samplepggeometrycollectionm_id)
> >>>>> WITH (
> >>>>> OIDS=FALSE
> >>>>> ALTER TABLE public.samplepggeometrycollectionm
> >>>>> OWNER TO postgres;
> >>>>> Awaiting ur suggestions.
> >>>>> Baris
> >>>>> _______________________________________________
> >>>>> postgis-users mailing list
> >>>>> postgis-users at lists.osgeo.org
> >>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> >>> Barış
> >>> www.linkedin.com/in/barisergun
> >> Barış
> > Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131227/cf49b5c3/attachment.html>
