[postgis-users] GDAL problems (Kyngesbury GDAL)
William Kyngesburye
woklist at kyngchaos.com
Sat Dec 28 16:53:37 PST 2013
It won't show up in the general console log, there's a separate section for crash logs (User Diaognostic Reports section).
On Dec 28, 2013, at 6:51 PM, Dheeraj Chand wrote:
> Nope, nothing. I am going to try again with 1.9 after dinner and send the results. This is the closest that I could find in Console:
> 12/28/13 6:33:47.063 PM sudo[48980]: dheerajchand : TTY=ttys000 ; PWD=/Users/dheerajchand/Python_Environments/geo ; USER=root ; COMMAND=/usr/bin/find / -name gdal-config
> Best,
> -dx
> On Dec 28, 2013, at 6:48 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Is there a crash report in Console.app from when you try to load GDAL python? It will probably be as python.
>> On Dec 28, 2013, at 6:27 PM, Dheeraj Chand wrote:
>>> William,
>>> Thanks for responding. I was using the 1.10 because I updated when you updated. I got the same kind of error when I used 1.9, though. I'd be more than happy to try again and show you, though. Do you think that it's necessary?
>>> Best,
>>> -dx
>>> On Dec 28, 2013, at 11:46 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>>> Sorry, I didn't read to the very end, where you did recompile with the --include-dirs option.
>>>> The missing lib/ warning is no problem, just a warning.
>>>> The segfault though, doesn't say enough to figure out what's wrong. Maybe there is something in the Console.app, like a crash report (User Diaognostic Reports section).
>>>> On Dec 28, 2013, at 11:38 AM, William Kyngesburye wrote:
>>>>> The compile flag to set the GDAL include dir is wrong for the framework. It seems to be assuming that the framework is a 'nix lib/include structure, but really the include dir is named "Headers". Odd that it uses supposedly gdal-config, but doesn't get the -cflags from it that have the correct include dir.
>>>>> I see that Tim's instructions actually call for using --include-dirs=/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/
>>>>> I wonder: Tim, what is it about the "virtual environment" that makes the existing GDAL python in the framework not work? (I don't know anything about python virtual env)
>>>>> On Dec 27, 2013, at 10:33 PM, Dheeraj Chand wrote:
>>>>>> Hi, all,
>>>>>> I was working on a project, that at a high level, can be described as :
>>>>>> 1. Connect Python to PostGIS,
>>>>>> 2. Grab spatial tables' data,
>>>>>> 3. *PROCESS*,
>>>>>> 4. Spit out shapefiles.
>>>>>> In the process of doing this, I was trying to use the Python GDAL library in a new virtualenv called geo, but I got these errors. I am using William Kyngesbury's GDAL 1.10 for OS X, and I'm running into crazy errors. I am following the instructions from here (http://linfiniti.com/2013/02/installing-python-gdal-into-a-python-virtualenv-in-osx/), and this is what happened in my shell.
>>>>>> Can anyone help me out?
>>>>>> Best,
>>>>>> -dx
>>>>>> (geo)REINHEIT:GDAL dheerajchand$ python
>>>>>> Python 2.7.3 (v2.7.3:70274d53c1dd, Apr 9 2012, 20:52:43)
>>>>>> [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)] on darwin
>>>>>> Type "help", "copyright", "credits" or "license" for more information.
>>>>>>>>> from osgeo import gdal
>>>>>>>>> gdal.__version__
>>>>>> Segmentation fault: 11
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> Earth: "Mostly harmless"
>> - revised entry in the HitchHiker's Guide to the Galaxy
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
