[postgis-users] Fedora 18: PostGIS/Postgresql interoperability
Max Pyziur pyz at brama.com
Mon Feb 4 15:44:09 PST 2013
Greetings,
Fedora 18 was released w/ Postgresql 9.2.x and PostGIS 1.5.x
As (I guess) it is known PostGIS 1.5.x won't work on Postgresql 9.2.
However, there haven't been any production PostGIS 2.0.- RPMs released;
however, there are some in testing. You also have to install the GDAL and
GRASS RPMs that are in testing.
Thanks to previous replies, I've downloaded those F18 PostGIS 2.0 rpms and
they function. I have don't a complete test, but I've migrated my
spatialized databases to Postgresql 9.2/PostGIS 2.0 and using both psql
and Quantum GIS I can access my projects.
However, there are still some issues, two of which that affect me.
1 - when doing a generalized "yum update" (to check for updates) I get the
following message:
root at mercury ~> yum update
Loaded plugins: langpacks, presto, refresh-packagekit
Resolving Dependencies
--> Running transaction check
---> Package libwebp.x86_64 0:0.1.3-2.fc18 will be updated
--> Processing Dependency: libwebp.so.2()(64bit) for package:
gdal-libs-1.9.1-15.fc18.1.x86_64
gdal-1.9.1-15.fc18.1.x86_64
---> Package libwebp.x86_64 0:0.2.1-1.fc18 will be an update
--> Finished Dependency Resolution
Error: Package: gdal-libs-1.9.1-15.fc18.1.x86_64 (installed)
            Requires: libwebp.so.2()(64bit)
            Removing: libwebp-0.1.3-2.fc18.x86_64 (@fedora)
            Updated By: libwebp-0.2.1-1.fc18.x86_64 (updates)
                Not found
Error: Package: gdal-1.9.1-15.fc18.1.x86_64 (installed)
                Not found
  You could try using --skip-broken to work around the problem
  You could try running: rpm -Va --nofiles --nodigest
So, there are potential problems based on different versions of
gdal, grass, and postgis.
2 - there was no postgis-jdbc 2.0 released for testing for Fedora 18;
That makes using something like OpenJUMP (Open Java Unified Mapping
Program) not useable. (I use both Q-GIS and OpenJUMP).
Any sense of when there could be a postgis-jdbc 2.0.x package available?
Much thanks to all,
Max Pyziur
pyz at brama.com
