[postgis-users] Fedora 18: PostGIS/Postgresql interoperability
Paul Ramsey pramsey at cleverelephant.ca
Wed Feb 20 09:48:12 PST 2013
Rather than using the postgresql packages included in the distro, go to the postgresl yum repo. That always has much fresher versions, of both pgsql and postgis.
http://yum.postgresql.org
P
Paul Ramsey
http://cleverelephant.ca/
http://postgis.net/
On Monday, 4 February, 2013 at 3:44 PM, Max Pyziur wrote:
> Greetings,
> Fedora 18 was released w/ Postgresql 9.2.x and PostGIS 1.5.x
> As (I guess) it is known PostGIS 1.5.x won't work on Postgresql 9.2.
> However, there haven't been any production PostGIS 2.0.- RPMs released;
> however, there are some in testing. You also have to install the GDAL and
> GRASS RPMs that are in testing.
> Thanks to previous replies, I've downloaded those F18 PostGIS 2.0 rpms and
> they function. I have don't a complete test, but I've migrated my
> spatialized databases to Postgresql 9.2/PostGIS 2.0 and using both psql
> and Quantum GIS I can access my projects.
> However, there are still some issues, two of which that affect me.
> 1 - when doing a generalized "yum update" (to check for updates) I get the
> following message:
> root at mercury ~> yum update
> Loaded plugins: langpacks, presto, refresh-packagekit
> Resolving Dependencies
> --> Running transaction check
> ---> Package libwebp.x86_64 0:0.1.3-2.fc18 will be updated
> --> Processing Dependency: libwebp.so.2()(64bit) for package:
> gdal-libs-1.9.1-15.fc18.1.x86_64
> gdal-1.9.1-15.fc18.1.x86_64
> ---> Package libwebp.x86_64 0:0.2.1-1.fc18 will be an update
> --> Finished Dependency Resolution
> Error: Package: gdal-libs-1.9.1-15.fc18.1.x86_64 (installed)
> Requires: libwebp.so.2()(64bit)
> Removing: libwebp-0.1.3-2.fc18.x86_64 (@fedora)
> Updated By: libwebp-0.2.1-1.fc18.x86_64 (updates)
> Not found
> Error: Package: gdal-1.9.1-15.fc18.1.x86_64 (installed)
> Not found
> You could try using --skip-broken to work around the problem
> You could try running: rpm -Va --nofiles --nodigest
> So, there are potential problems based on different versions of
> gdal, grass, and postgis.
> 2 - there was no postgis-jdbc 2.0 released for testing for Fedora 18;
> That makes using something like OpenJUMP (Open Java Unified Mapping
> Program) not useable. (I use both Q-GIS and OpenJUMP).
> Any sense of when there could be a postgis-jdbc 2.0.x package available?
> Much thanks to all,
> Max Pyziur
> pyz at brama.com (mailto:pyz at brama.com)
> postgis-users mailing list
> postgis-users at lists.osgeo.org (mailto:postgis-users at lists.osgeo.org)
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130220/22a16fd9/attachment.html>
