[postgis-users] Fedora 18: PostGIS/Postgresql interoperability
Max Pyziur pyz at brama.com
Wed Feb 20 10:26:02 PST 2013
> Rather than using the postgresql packages included in the distro, go to
> the postgresl yum repo. That always has much fresher versions, of both
> pgsql and postgis.
> http://yum.postgresql.org
Thanks.
Rather than be on a bleeding edge ("much fresher versions"), it would be
better to have everything built to function within an integrated whole
(Fedora 18) (see issue regarding libwebp below). To that end, can any
information be offered as to when F18-/Postgresql-compliant Postgis RPMs
will be packaged and made available?
Much thanks.
> P
> Paul Ramsey
> http://cleverelephant.ca/
> http://postgis.net/
Max Pyziur
pyz at brama.com
> On Monday, 4 February, 2013 at 3:44 PM, Max Pyziur wrote:
>> Greetings,
>> Fedora 18 was released w/ Postgresql 9.2.x and PostGIS 1.5.x
>> As (I guess) it is known PostGIS 1.5.x won't work on Postgresql 9.2.
>> However, there haven't been any production PostGIS 2.0.- RPMs released;
>> however, there are some in testing. You also have to install the GDAL
>> and
>> GRASS RPMs that are in testing.
>> Thanks to previous replies, I've downloaded those F18 PostGIS 2.0 rpms
>> and
>> they function. I have don't a complete test, but I've migrated my
>> spatialized databases to Postgresql 9.2/PostGIS 2.0 and using both psql
>> and Quantum GIS I can access my projects.
>> However, there are still some issues, two of which that affect me.
>> 1 - when doing a generalized "yum update" (to check for updates) I get
>> the
>> following message:
>> root at mercury ~> yum update
>> Loaded plugins: langpacks, presto, refresh-packagekit
>> Resolving Dependencies
>> --> Running transaction check
>> ---> Package libwebp.x86_64 0:0.1.3-2.fc18 will be updated
>> --> Processing Dependency: libwebp.so.2()(64bit) for package:
>> gdal-libs-1.9.1-15.fc18.1.x86_64
>> gdal-1.9.1-15.fc18.1.x86_64
>> ---> Package libwebp.x86_64 0:0.2.1-1.fc18 will be an update
>> --> Finished Dependency Resolution
>> Error: Package: gdal-libs-1.9.1-15.fc18.1.x86_64 (installed)
>> Requires: libwebp.so.2()(64bit)
>> Removing: libwebp-0.1.3-2.fc18.x86_64 (@fedora)
>> Updated By: libwebp-0.2.1-1.fc18.x86_64 (updates)
>> Not found
>> Error: Package: gdal-1.9.1-15.fc18.1.x86_64 (installed)
>> Not found
>> You could try using --skip-broken to work around the problem
>> You could try running: rpm -Va --nofiles --nodigest
>> So, there are potential problems based on different versions of
>> gdal, grass, and postgis.
>> 2 - there was no postgis-jdbc 2.0 released for testing for Fedora 18;
>> That makes using something like OpenJUMP (Open Java Unified Mapping
>> Program) not useable. (I use both Q-GIS and OpenJUMP).
>> Any sense of when there could be a postgis-jdbc 2.0.x package available?
>> Much thanks to all,
>> Max Pyziur
>> pyz at brama.com (mailto:pyz at brama.com)
