[postgis-users] Break polylines by points
Aitor Gil Martin
agmartin at getxo.net
Wed Feb 6 05:07:04 PST 2013
I've got some problem for achieving what you said.
I've got a lot of cases where the linestring is intersected by 2 points. I would need to have 3 linestrings as a result of the split operation and as far as I can understand St_split only cuts a geometry with another geometry.
Maybe I could do it in QGIS or another program?
Regards,
Aitor
De: pcreso at pcreso.com [mailto:pcreso at pcreso.com]
Enviado el: viernes, 01 de febrero de 2013 21:25
Para: Aitor Gil Martin
Asunto: Re: [postgis-users] Break polylines by points
See the example of splitting a Polyline by a point at:
http://postgis.refractions.net/documentation/manual-svn/ST_Split.html
You'll need to decompose the collection (ST_Dump() ) and you can limit the points/lines being split by use a where clause that restricts the result set to lines with points that intersect the line.
Of course, if the point does not lie exactly on the linestring, this will fail, which in many datasets can be quite likely. You can address this, if it is an issue, by generating buffers around the points, selecting the intersection of each linestring with the buffer, then storing the "adjusted" point (valve) location as the midpoint of the linestring intersection.
If you really wanted a geosynchronous point/line dataset, assuming the valve point locations are more accurate than the lines, you could then find all those linestring endpoints which are now an adjusted point location, & update each to the original (rather than adjusted) point location.
Cheers,
Brent Wood
--- On Sat, 2/2/13, Aitor Gil Martin <agmartin at getxo.net> wrote:
Subject: [postgis-users] Break polylines by points
To: postgis-users at lists.osgeo.org
Date: Saturday, February 2, 2013, 3:49 AM
Hi all,
I would like to split the polylines (pipes) with the points (valves). If a point intersects a polyline, this polyline should be transformed into two polylines. Both tables have 7000 records aprox.
Regards,
Aitor Gil Martin
Departamento Informática
Getxoko Udala / Ayto Getxo
Tel: 94 466 02 16 Ext.- 3457
www.getxo.net <http://www.getxo.net/>
-----Inline Attachment Follows-----
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130206/2e0855c3/attachment.html>
