[postgis-users] Feature request: projection parameter as PROJ-string (not only as EPSG number
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Feb 18 07:39:19 PST 2013
On 02/18/2013 04:02 PM, Sandro Santilli wrote:
> On Mon, Feb 18, 2013 at 03:33:43PM +0100, Jan Hartmann wrote:
>> Would it be possible to extend functions as st_transform with a
>> version, where the second parameter is not an EPSG-number but a full
>> PROJ-string?
> It's already available.
> Maybe not documented, but it is postgis_transform_geometry(),
> check your pg_proc.
> If it's not documented consider submitting a patch for docs.
> --strk;
Done
Jan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130218/c93cbede/attachment.html>
