[postgis-users] Feature request: projection parameter as PROJ-string (not only as EPSG number
Sandro Santilli strk at keybit.net
Mon Feb 18 07:02:31 PST 2013
On Mon, Feb 18, 2013 at 03:33:43PM +0100, Jan Hartmann wrote:
> Would it be possible to extend functions as st_transform with a
> version, where the second parameter is not an EPSG-number but a full
> PROJ-string?
It's already available.
Maybe not documented, but it is postgis_transform_geometry(),
check your pg_proc.
If it's not documented consider submitting a patch for docs.
--strk;
