[postgis-users] trace back
Andy Colson
andy at squeakycode.net
Tue Feb 19 11:17:06 PST 2013
> On 2/19/2013 12:35 PM, Jonatan Malaver wrote:
>> Hello,
>> Let's say I have 3 parcel centroids with one feature in common. How
>> would I do a trace back to the common feature between those points?
>> Also, how can I do a flood analysis?
>> Thanks,
>> Jonatan Malaver
>> Assistant Engineer of Electrical and Cable Operations
>> Shrewsbury Electric & Cable Operations
>> 100 Maple Avenue
>> Shrewsbury, MA 01545
>> Office: 508.841.1520
>> Mobile: 774.262.0437
>> Fax: 508.842.9267
>> jon.malaver at shrewsburyma.gov <mailto:jon.malaver at shrewsburyma.gov>
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> That's pretty vague. So you have parcel points, and not polygons? In a table called ParcelPoints?
> What is this feature? Is it a column in table ParcelPoints? Or is it a point in a different table? Is it a polygon? Is it in a table or are you hard coding it in wkt? (like "POINT(42 42)")
> -Andy
On 2/19/2013 1:12 PM, Jonatan Malaver wrote:> Let me give you more info.
I'm trying to sync my GIS with our outage management system (small
electric utility). I would like to trace back an outage call (customer
points) to a common transformer (point), fuse (point), or station
(point). All the points are in different tables, and they are all
intersected by a line (circuit).
> Thanks,
> Jonatan Malaver
> 100 Maple Avenue
> Fax: 508.842.9267
> -----Original Message-----
> From: Andy Colson [mailto:andy at squeakycode.net]
> Sent: Tuesday, February 19, 2013 2:04 PM
> To: PostGIS Users Discussion
> Cc: Jonatan Malaver
> Subject: Re: [postgis-users] trace back
Hum... As a test, can you do something like:
select *
from circuit
inner join station on ST_Intersects(circut.geom, station.geom)
where circuit.id = 42;
The id = 42 is meant to only pull back one line of the circuit, and the
join is to see if it'll match all the stations on that line.
-Andy
