[postgis-users] not so Weird behaviour of ST_Project (PostGIS2)
Martin Feuchtwanger feumar at shaw.ca
Fri Feb 22 10:57:17 PST 2013
Things behave as you'd expect going north/south because meridians of
longitude are great circles (shortest paths on globe).
However, when you go east/west, parallels of latitude and great circles
(shortest paths) are *not* the same. Parallels are convenient lines
representing the graticule and represent /orthodromes/ (lines of
constant azimuth) but are not true great circles (which, presumably,
st_project is following).
(FYI, if you were to follow an orthodrome in any other azimuth but the
four cardinal directions, you'd spiral towards a pole!)
Spherical trigonometry's not always simple ;-)
Martin Feuchtwanger  feumar at shaw.ca  604-254-0361
Vancouver, BC  V5N 1J6
http://members.shaw.ca/geomatics.developer
On 21/02/2013 12:15 AM, News and Such wrote:
> Hello postgis'ers,
> somehow I can't understand the results of ST_Project, but maybe this
> problem is just me being stupid (again):
> I just want to project a point in North, East, South and West direction.
> Note:
> I use geography-type here, but the results are the same for geometry.
> I use a rather long distance, because I need it, at least in one
> direction, for my application. Because of this I found the "problem"
> in the first place.
> With the direction north, everything is as I expect it:
> |SELECT ST_AsText(ST_Project('POINT(-30 -0.5)'::geography, 1e7,
> radians(0)));
> st_astext -----------------------------
> POINT(-30 89.4874128664049) |
> But in the other directions, here for example East, I get this:
> radians(90)));
> st_astext ---------------------------------------------
> POINT(59.8315233716443 0.00116689648502556) |
> Shouldn't this be |POINT(59.8315233716443 -0.5)| ? Why are both
> coordinates changing?
> This behaviour occurs in all directions save north.
> I'm new to the whole earth coordinate system-stuff so maybe I missed
> something, but I thought that when one walks directly west (or south)
> one would, by definition, not leave the current longitude (or
> latitude)-line but only change the other.
> Any help would be appreciated!
> Thank you.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130222/fd52306b/attachment.html>
