[postgis-users] not so Weird behaviour of ST_Project (PostGIS2)
Martin Feuchtwanger
feumar at shaw.ca
Fri Feb 22 11:09:41 PST 2013
I correct myself:
line of constant azimuth = */loxodrome /*(or rhumb line)
shortest path = /orthodrome /(or great circle)
(the concept was correct; i was mixing up the terms)
Martin Feuchtwanger feumar at shaw.ca 604-254-0361
302 - 1429 E 4th Ave, Vancouver, BC V5N 1J6
http://members.shaw.ca/geomatics.developer
skype: martin.feuchtwanger
On 22/02/2013 10:57 AM, Martin Feuchtwanger wrote:
> Things behave as you'd expect going north/south because meridians of
> longitude are great circles (shortest paths on globe).
> However, when you go east/west, parallels of latitude and great
> circles (shortest paths) are *not* the same. Parallels are convenient
> lines representing the graticule and represent /orthodromes/ (lines of
> constant azimuth) but are not true great circles (which, presumably,
> st_project is following).
> (FYI, if you were to follow an orthodrome in any other azimuth but the
> four cardinal directions, you'd spiral towards a pole!)
> Spherical trigonometry's not always simple ;-)
> Martin Feuchtwangerfeumar at shaw.ca 604-254-0361
> On 21/02/2013 12:15 AM, News and Such wrote:
>> Hello postgis'ers,
>> somehow I can't understand the results of ST_Project, but maybe this
>> problem is just me being stupid (again):
>> I just want to project a point in North, East, South and West direction.
>> Note:
>> I use geography-type here, but the results are the same for geometry.
>> I use a rather long distance, because I need it, at least in one
>> direction, for my application. Because of this I found the "problem"
>> in the first place.
>> With the direction north, everything is as I expect it:
>> |SELECT ST_AsText(ST_Project('POINT(-30 -0.5)'::geography, 1e7,
>> radians(0)));
>> st_astext -----------------------------
>> POINT(-30 89.4874128664049) |
>> But in the other directions, here for example East, I get this:
>> radians(90)));
>> st_astext ---------------------------------------------
>> POINT(59.8315233716443 0.00116689648502556) |
>> Shouldn't this be |POINT(59.8315233716443 -0.5)| ? Why are both
>> coordinates changing?
>> This behaviour occurs in all directions save north.
>> I'm new to the whole earth coordinate system-stuff so maybe I missed
>> something, but I thought that when one walks directly west (or south)
>> one would, by definition, not leave the current longitude (or
>> latitude)-line but only change the other.
>> Any help would be appreciated!
>> Thank you.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130222/168640ad/attachment.html>
