[postgis-users] Upgrade to postgis 2.1 : error message
laurent
lcelati at latitude-geosystems.com
Tue Feb 26 03:33:03 PST 2013
Hello,
Thanks to your following message, i'm following the part of the doc
regarding the upgrade called "
2.9.1.2. Soft Upgrade 9.1+ using extensions ".
In a 1st time i tied to tape this sql query :
ALTER EXTENSION postgis UPDATE TO "2.1.0SVN";
ALTER EXTENSION postgis_topology UPDATE TO "2.1.0SVN";
But i received an error message saying
ERREUR: l'extension « postgis » n'a pas de chemin de mise à jour pour aller
de la version « 2.0.0 » à la version « 2.1.0SVN »
********** Erreur **********
État SQL :22023
So i tried to backup my db thanks to pg_dump. But i received this following
error message :
<http://postgis.17.n6.nabble.com/file/n5002687/SS_error_dump.JPG>
This error message is trange because i try to save my .sql file toward a
drive with 2,91 To available...
In advance, thank you.
View this message in context: http://postgis.17.n6.nabble.com/Upgrade-postgis-2-0-to-postgis-2-01-or-2-02-tp5002684p5002687.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
