[postgis-users] Fedora 18: PostGIS/Postgresql interoperability
Max Pyziur pyz at brama.com
Thu Feb 28 08:38:51 PST 2013
Greetings,
Any guidence on when F18 PostGIS/Postgresql issues will be resolved?
Are there better forums where to post questions and follow discussions on
these issues?
Much thanks,
Max Pyziur
pyz at brama.com
---------- Forwarded message ----------
Date: Mon, 4 Feb 2013 18:44:09 -0500 (EST)
To: postgis-users at lists.osgeo.org
Subject: Fedora 18: PostGIS/Postgresql interoperability
Greetings,
Fedora 18 was released w/ Postgresql 9.2.x and PostGIS 1.5.x
As (I guess) it is known PostGIS 1.5.x won't work on Postgresql 9.2.
However, there haven't been any production PostGIS 2.0.- RPMs released;
however, there are some in testing. You also have to install the GDAL and GRASS
RPMs that are in testing.
Thanks to previous replies, I've downloaded those F18 PostGIS 2.0 rpms and they
function. I have don't a complete test, but I've migrated my spatialized
databases to Postgresql 9.2/PostGIS 2.0 and using both psql and Quantum GIS I
can access my projects.
However, there are still some issues, two of which that affect me.
1 - when doing a generalized "yum update" (to check for updates) I get the
following message:
root at mercury ~> yum update
Loaded plugins: langpacks, presto, refresh-packagekit
Resolving Dependencies
-->  Running transaction check
---> Package libwebp.x86_64 0:0.1.3-2.fc18 will be updated
-->  Processing Dependency: libwebp.so.2()(64bit) for package:
gdal-libs-1.9.1-15.fc18.1.x86_64
gdal-1.9.1-15.fc18.1.x86_64
---> Package libwebp.x86_64 0:0.2.1-1.fc18 will be an update
-->  Finished Dependency Resolution
Error: Package: gdal-libs-1.9.1-15.fc18.1.x86_64 (installed)
             Requires: libwebp.so.2()(64bit)
             Removing: libwebp-0.1.3-2.fc18.x86_64 (@fedora)
             Updated By: libwebp-0.2.1-1.fc18.x86_64 (updates)
                Not found
Error: Package: gdal-1.9.1-15.fc18.1.x86_64 (installed)
                 Not found
   You could try using --skip-broken to work around the problem
   You could try running: rpm -Va --nofiles --nodigest
So, there are potential problems based on different versions of gdal, grass,
and postgis.
2 - there was no postgis-jdbc 2.0 released for testing for Fedora 18;
That makes using something like OpenJUMP (Open Java Unified Mapping Program)
not useable. (I use both Q-GIS and OpenJUMP).
Any sense of when there could be a postgis-jdbc 2.0.x package available?
Much thanks to all,
Max Pyziur
pyz at brama.com
