[postgis-users] Fedora 18: PostGIS/Postgresql interoperability
Devrim Gündüz devrim at gunduz.org
Thu Feb 28 10:46:07 PST 2013
Max Pyziur <pyz at brama.com> wrote:
>Greetings,
>Any guidence on when F18 PostGIS/Postgresql issues will be resolved?
>Are there better forums where to post questions and follow discussions
>on
>these issues?
>Much thanks,
>Max Pyziur
>pyz at brama.com
>---------- Forwarded message ----------
>Date: Mon, 4 Feb 2013 18:44:09 -0500 (EST)
>From: Max Pyziur <pyz at brama.com>
>To: postgis-users at lists.osgeo.org
>Subject: Fedora 18: PostGIS/Postgresql interoperability
>Greetings,
>Fedora 18 was released w/ Postgresql 9.2.x and PostGIS 1.5.x
>As (I guess) it is known PostGIS 1.5.x won't work on Postgresql 9.2.
>However, there haven't been any production PostGIS 2.0.- RPMs released;
>however, there are some in testing. You also have to install the GDAL
>and GRASS
>RPMs that are in testing.
>Thanks to previous replies, I've downloaded those F18 PostGIS 2.0 rpms
>and they
>function. I have don't a complete test, but I've migrated my
>spatialized
>databases to Postgresql 9.2/PostGIS 2.0 and using both psql and Quantum
>GIS I
>can access my projects.
>However, there are still some issues, two of which that affect me.
>1 - when doing a generalized "yum update" (to check for updates) I get
>the
>following message:
>root at mercury ~> yum update
>Loaded plugins: langpacks, presto, refresh-packagekit
>Resolving Dependencies
>-->  Running transaction check
>---> Package libwebp.x86_64 0:0.1.3-2.fc18 will be updated
>-->  Processing Dependency: libwebp.so.2()(64bit) for package:
>gdal-libs-1.9.1-15.fc18.1.x86_64
>gdal-1.9.1-15.fc18.1.x86_64
>---> Package libwebp.x86_64 0:0.2.1-1.fc18 will be an update
>-->  Finished Dependency Resolution
>Error: Package: gdal-libs-1.9.1-15.fc18.1.x86_64 (installed)
>             Requires: libwebp.so.2()(64bit)
>             Removing: libwebp-0.1.3-2.fc18.x86_64 (@fedora)
>             Updated By: libwebp-0.2.1-1.fc18.x86_64 (updates)
>                Not found
>Error: Package: gdal-1.9.1-15.fc18.1.x86_64 (installed)
>                 Not found
>   You could try using --skip-broken to work around the problem
>   You could try running: rpm -Va --nofiles --nodigest
>So, there are potential problems based on different versions of gdal,
>grass,
>and postgis.
>2 - there was no postgis-jdbc 2.0 released for testing for Fedora 18;
>That makes using something like OpenJUMP (Open Java Unified Mapping
>Program)
>not useable. (I use both Q-GIS and OpenJUMP).
>Any sense of when there could be a postgis-jdbc 2.0.x package
>available?
>Much thanks to all,
>Max Pyziur
>pyz at brama.com
>_______________________________________________
>postgis-users mailing list
>http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Updates were blocked by a Fedora contributor who wanted to push his security update for another package first.
Given that GeOS 3.3.8 was released today, and PostGIS 2.0.3 is very close, I can give another try this weekend.
Still, I strongly suggest you to use PostgreSQL RPM repo: http://yum.postgresql.org . It includes whatever you need.
Regards,
Devrim Gündüz
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130228/fbaa9b58/attachment.html>
