[postgis-users] ST_DWithin with a rectangular shape
zwieberl at lavabit.com zwieberl at lavabit.com
Sun Jan 6 23:51:20 PST 2013
Hello,
sorry for bumping this, but I still haven't found an answer and had no
replies.
Any help would be appreciated!
Thank you!
> Hello,
> I'm using Postgis 2.0.2 with Geography-Points only
> (satellite-measurements).
> I have two tables for two different satellites and need to find all Points
> from table A that are in the vicinity of the points in table B.
> Now ST_DWithin does this job amazingly well (200 s for 14.216.117 hits),
> but since earth is rotating I need an asymmetrical search-area (bigger
> longitudes than latitudes).
> Basically I need an ST_DWithin-function for rectangles, where I can give
> two distances (one in a direction parallel to the equator and one
> perpendicular to it) around a given point.
> Right now I was trying to solve the problem the following way:
> I create a POLYGON on-the-fly during the SELECT-statement out of points
> from table B using ST_Project and use than ST_Covers() on the created
> Polygon:
> select A.id, B.id from A, B WHERE ST_Covers(
> ST_GeogFromText(
> 'POLYGON(('
> || trim(trailing ')' from trim(leading 'POINT(' from
> ST_AsText(ST_Project(B.geo, 1500000, 0)))) || ','
> ST_AsText(ST_Project(B.geo, 1500000, 1.57)))) || ','
> ST_AsText(ST_Project(B.geo, 1500000, 3.1415)))) || ','
> ST_AsText(ST_Project(B.geo, 1500000, 4.71)))) || ','
> ), A.geo);
> Note 1: This Polygon is wrong! It is turned by 45°. I would need to do a
> ST_Project twice for every point, but for shortness I omitted it here.
> (I would need to do something like ST_Project(ST_Project(B.geo, 1500000,
> 1.57), 800000, 0) for every corner of the rectangle).
> Note 2: I know I can use ST_X(point::geometry) to extract the coordinates,
> but its basically the same with respect to performance, especially since I
> need to project the point then four times instead of two (twice for ST_X
> and twice for ST_Y)
> This solution is bad. Really, really bad! As stated above ST_DWithin does
> this in 200 s for 14 million hits. I had to cancel my solution after 4
> hours for the same tables.
> Does anybody know a solution to this problem?
> Any help would be really appreciated!
> Thank you!
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> ____________________________________________________________________________
