[postgis-users] ST_Transform error
Cedric Duprez
Cedric.Duprez at ign.fr
Mon Jan 7 05:37:28 PST 2013
Hi all and let me wish you a happy new year!
I am back with my coordinate transformations with custom records of spatial_sys_ref.
I have a little bit improved. First, I upgraded to Postgis 2.0.2 and PostgreSQL 9.2.1.
Then, I recompiled Proj4 with proj-datum grid 1.5 in the /nad directory of proj4 (what I forgot during the last installation).
Now, I insert my custom spatial references like this:
insert into spatial_ref_sys values (910001,'IGNF',310024140,'PROJCS["Lambert 93",GEOGCS["Réseau géodésique français 1993",DATUM["Réseau géodésique français 1993",SPHEROID["IAG GRS 1980",6378137.0000,298.2572221010000,AUTHORITY["IGNF","ELG037"]],TOWGS84[0.0000,0.0000,0.0000,0,0,0,0],AUTHORITY["IGNF","REG024"]],PRIMEM["Greenwich",0.000000000,AUTHORITY["IGNF","LGO01"]],UNIT["degree",0.01745329251994330],AXIS["Longitude",EAST],AXIS["Latitude",NORTH],AUTHORITY["IGNF","RGF93G"]],PROJECTION["Lambert_Conformal_Conic_2SP",AUTHORITY["IGNF","PRC0140"]],PARAMETER["semi_major",6378137.0000],PARAMETER["semi_minor",6356752.3141],PARAMETER["latitude_of_origin",46.500000000],PARAMETER["central_meridian",3.000000000],PARAMETER["standard_parallel_1",44.000000000],PARAMETER["standard_parallel_2",49.000000000],PARAMETER["false_easting",700000.000],PARAMETER["false_northing",6600000.000],UNIT["metre",1],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["IGNF","LAMB93"]]','+init=IGNF:LAMB93');
insert into spatial_ref_sys values (910002,'IGNF',320002120,'PROJCS["Lambert II étendu",GEOGCS["Nouvelle Triangulation Française Paris grades",DATUM["NTF",SPHEROID["Clarke 1880 IGN",6378249.2000,293.4660210000000,AUTHORITY["IGNF","ELG010"]],TOWGS84[-168.0000,-60.0000,320.0000,0,0,0,0],AUTHORITY["IGNF","REG002"]],PRIMEM["Paris",2.337229167,AUTHORITY["IGNF","LGO02"]],UNIT["grad",0.01570796326794897],AXIS["Longitude",EAST],AXIS["Latitude",NORTH],AUTHORITY["IGNF","NTFP"]],PROJECTION["Lambert_Conformal_Conic_1SP",AUTHORITY["IGNF","PRC0120"]],PARAMETER["semi_major",6378249.2000],PARAMETER["semi_minor",6356515.0000],PARAMETER["latitude_of_origin",46.800000000],PARAMETER["central_meridian",0.000000000],PARAMETER["scale_factor",0.99987742],PARAMETER["false_easting",600000.000],PARAMETER["false_northing",2200000.000],UNIT["metre",1],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["IGNF","LAMBE"]]','+init=IGNF:LAMBE');
Then, I try to convert Lambert II coordinates into Lambert 93 like this:
SELECT *, ST_Transform(ST_SetSRID(ST_MakePoint(xl, yl), 910002), 910001) AS geom
FROM (values (556866, 1902345) , (689174, 2448195) , (729095, 2528577) , (335755, 2059702) , (623207, 2210468) , (850337, 1871486) , (915275, 1889534) , (639551, 1778327) , (584365, 2273523) , (649599, 2228833)) as t(xl, yl);
But I get the following error: "lwgeom_transform: Cannot handle type 'Invalid type'"
Any idea of what causes this error?
Thanks in advance for your help.
Regards,
Cedric Duprez
