[postgis-users] ST_Transform error
Sandro Santilli
strk at keybit.net
Mon Jan 7 07:05:22 PST 2013
On Mon, Jan 07, 2013 at 03:42:20PM +0100, Cedric Duprez wrote:
> Thanks for your help.
> >The error sounds like due to a mixed use of old and new library functions.
> >Try this query:
> > select distinct p.probin from pg_proc p where p.probin like '%postgis%';
> >You should get only 2 rows.
> The query gives me the following lines:
> $libdir/postgis-2.0
> $libdir/rtpostgis-2.0
> So, it seems to be OK, no?
Yes
> >How did you upgrade ?
> I am on an Ubuntu 12.04 server.
> I uninstalled postgis extension 2.0.1, uninstalled postgis using make uninstall under the compiled sources directory.
> Then I uninstalled Proj4 in the same way, recompiled after having unzipped proj-datum grid 1.5 in the nad directory.
> Then I recompiled the new postgis 2.0.2 from sources and finally installed the extensions.
> Have I done something wrong? How can I do to correct my installation?
Actually it seems all fine to me.
Can you reproduce with any other SRID value ?
--strk;
