[postgis-users] PostGIS on ArcGIS AND AutoCAD Civil 3D 2013
Mark Volz MarkVolz at co.lyon.mn.us
Mon Jan 7 10:07:48 PST 2013
Hello,
I installed PostgreSQL 9.1 64 bit and PostGIS 2.0.1 to host spatial data for our ArcGIS, which can be done via the ArcGIS "Add query layer" option.  Now that I got that working I have had a couple people ask if I can get our AutoCad Civil 3D 2013 users connected to PostGIS as well.   I noticed right off hand that AutoCAD connects to the postgresql, however even with the spatial reference system loaded the data does not appear to load properly.  I found a note that Civil 3D may not work with Postgresql 9.1 and PostGIS 2.0.  Is this correct?
Has anyone found a combination of PostgreSQL and PostGIS that will serve data to both ArcGIS and AutoCAD clients?
Thank You
P.S.  This data is not "SDE" It is strictly postgreSQL and postgis.
Mark Volz
GIS Specialist
