[postgis-users] ST_Transform error (proj4 string error)
Cedric Duprez Cedric.Duprez at ign.fr
Thu Jan 31 07:47:36 PST 2013
After a full uninstall from sources and complete recompilation from sources, everything works correctly.
I don't know the reason of the error message.
The only thing I changed was the GEOS version (3.3.7).
So, now, it's OK.
Thanks for the help.
Regards,
Cedric
> I tried an install under WinXP.
> Everything works good and projection results are OK.
> So, the problem, on my Ubuntu server, seems to come from my build from
> sources.
> The postgis_full_version() gives :
> POSTGIS="2.0.2 r10789" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March
> 2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" TOPOLOGY RASTER
> This means that PROJ4 is detected as version 4.8.0, which is OK.
> Why doesn't ST_Transform find my IGNF:LAMBE system?
> Thanks for your help.
> cedric
