[postgis-users] ST_Transform error (proj4 string error)
ced
Cedric.DUPREZ at ign.fr
Mon Jan 28 08:43:44 PST 2013
I tried an install under WinXP.
Everything works good and projection results are OK.
So, the problem, on my Ubuntu server, seems to come from my build from
sources.
The postgis_full_version() gives :
POSTGIS="2.0.2 r10789" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
LIBJSON="UNKNOWN" TOPOLOGY RASTER
This means that PROJ4 is detected as version 4.8.0, which is OK.
Why doesn't ST_Transform find my IGNF:LAMBE system?
Thanks for your help.
cedric
View this message in context: http://postgis.17.n6.nabble.com/Coordinate-transformation-with-custom-records-of-spatial-sys-ref-tp4998668p5002455.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
