[postgis-users] VMWare and PostGIS
Paragon Corporation
lr at pcorp.us
Sat Jan 12 20:39:53 PST 2013
On a related topic, has anyone tried the VMware Postgres product. I'd be
curious to know how they optimized the performance for that and if it
supports PostGIS. I assume it does, but perhaps David Fetter if he's
listening can fill us in on that.
http://www.vmware.com/products/application-platform/vfabric-postgres/overvie
w.html
Thanks,
Regina
_____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Saturday, January 12, 2013 8:18 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] VMWare and PostGIS
The most important thing is to figure out where your "fast enough" place is,
and not get too hung up on the "fastest" thing. If we wanted to be fastest,
we'd all drive Ducatis to work, but clearly fast enough works for most of
us.
The main problem with AWS is not the virtualization, it's the shared
tenancy. It's possible for other tenants to saturate the I/O at
unpredictable times, taking it from acceptable to non-existent, with no
predicability. This will be true, though to a lesser extent, with private
virtual environments, like shared VMWare hosts run by your IT department.
("To a lesser extent" because AWS storage is network mounted, so everything
the host does with I/O has to push out through a network pipe. Your IT
department VMWare host, on the other hand, will at least have separate
network and storage I/O channels.)
I have heard of, but never seen, VMWare hosts that attach directly to SAN
storage over iSCSI. So the host is virtual, but the storage is at full SAN
speed. A "best of both worlds" situation, but with the added cost of SAN
infrastructure.
P.
On Sat, Jan 12, 2013 at 4:36 PM, Stephen V. Mather
<svm at clevelandmetroparks.com> wrote:
Hi All,
I should have asked this a long time ago regarding performance... . So the
classic storage solution (AFAIK) for a spatial database is RAID 10 for
maximum read and write speed. I have a RAID 10 running under a
virtualization layer (VMWare in this case) and my sustained read speeds are
in the 1Gbps range. The hardware is oldish, but they are 10k SAS drives, so
I would expect something a bit faster.
To the question-- I know virtualization makes a (not-so-good)
difference in performance running spatial databases on e.g. Amazon EC2
instances. I assume this penalty is paid even for dedicated private clouds.
What is the consensus/experience with virtualization? For my next machine,
should I keep it to bare metal for the PostGIS portion?
Thanks in advance,
Best,
Steve
http://sig.cmparks.net/cmp-ms-90x122.png Stephen V. Mather
GIS Manager
(216) <tel:%28216%29%20635-3243> 635-3243 (Work)
<http://www.clemetparks.com>
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130112/dc8d382d/attachment.html>
