[postgis-users] clip polygons
Francisco Salas
fsalas at pinar.geocuba.cu
Mon Jan 14 09:22:57 PST 2013
Martha ,
I think that you must use in the select sentence st_intersects(a.the_geom,
b.the_geom) as the_geom , instead of a.the_geom
Francisco Salas
De: postgis-users-bounces at lists.osgeo.org
[mailto:postgis-users-bounces at lists.osgeo.org] En nombre de Marta Debolini
Enviado el: lunes, 14 de enero de 2013 12:01 p.m.
Para: postgis-users at lists.osgeo.org
Asunto: [postgis-users] clip polygons
I am a new postgis user, so sorry if my request seems trivial for someone.
I have to clip a polygon with another polygon file. I was used to do this
operation with the simple comand "clip" in GRASS or QGIS.
How can I do the same operation in postgis? I tried with sy_intersect, but
it takes also the polygons outside my area, which simply intersect the
border.
The request I wrote is:
CREATE TABLE w_md.x
AS (SELECT area, a.the_geom
FROM oc a, co b
WHERE st_intersects(a.the_geom, b.the_geom));
ALTER TABLE w_md.x_1999 ADD column ggid1 serial;
ALTER TABLE w_mdi.x_1999 ADD PRIMARY KEY (ggID1);
Thank you for your help,
Marta
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130114/331391e2/attachment.html>
