[postgis-users] clip polygons
Tim-Hinnerk Heuer th.heuer at gmail.com
Mon Jan 14 17:14:32 PST 2013
I think Nicolas is more correct. St_Intersection sounds like a function
that gets a geometry while St_Intersects returns a Boolean.
On Jan 15, 2013 6:24 AM, "Francisco Salas" <fsalas at pinar.geocuba.cu> wrote:
> Martha ,****
> I think that you must use in the select sentence st_intersects(a.the_geom,
> b.the_geom) as the_geom , instead of a.the_geom****
> Francisco Salas
> *De:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *En nombre de *Marta Debolini
> *Enviado el:* lunes, 14 de enero de 2013 12:01 p.m.
> *Para:* postgis-users at lists.osgeo.org
> *Asunto:* [postgis-users] clip polygons****
> Hi,
> I am a new postgis user, so sorry if my request seems trivial for someone.
> I have to clip a polygon with another polygon file. I was used to do this
> operation with the simple comand "clip" in GRASS or QGIS.
> How can I do the same operation in postgis? I tried with sy_intersect, but
> it takes also the polygons outside my area, which simply intersect the
> border.
> The request I wrote is:
> CREATE TABLE w_md.x
> AS (SELECT area, a.the_geom
>     FROM oc a, co b
>     WHERE st_intersects(a.the_geom, b.the_geom));
>     ALTER TABLE w_md.x_1999 ADD column ggid1 serial;
>      ALTER TABLE w_mdi.x_1999 ADD PRIMARY KEY (ggID1);
> Thank you for your help,
> Marta****
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130115/f377f55b/attachment.html>
