[postgis-users] clip polygons
Martin Davis
mtnclimb at telus.net
Mon Jan 14 20:41:34 PST 2013
Correct. See http://postgis.net/docs/manual-2.0/ST_Intersection.html
On 1/14/2013 5:14 PM, Tim-Hinnerk Heuer wrote:
> I think Nicolas is more correct. St_Intersection sounds like a
> function that gets a geometry while St_Intersects returns a Boolean.
> On Jan 15, 2013 6:24 AM, "Francisco Salas" <fsalas at pinar.geocuba.cu
> <mailto:fsalas at pinar.geocuba.cu>> wrote:
> Martha ,
> I think that you must use in the select sentence
> st_intersects(a.the_geom, b.the_geom) as the_geom , instead of
> a.the_geom
> Francisco Salas
> *De:*postgis-users-bounces at lists.osgeo.org
> <mailto:postgis-users-bounces at lists.osgeo.org>
> [mailto:postgis-users-bounces at lists.osgeo.org
> <mailto:postgis-users-bounces at lists.osgeo.org>] *En nombre de
> *Marta Debolini
> *Enviado el:* lunes, 14 de enero de 2013 12:01 p.m.
> *Para:* postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> *Asunto:* [postgis-users] clip polygons
> Hi,
> I am a new postgis user, so sorry if my request seems trivial for
> someone.
> I have to clip a polygon with another polygon file. I was used to
> do this operation with the simple comand "clip" in GRASS or QGIS.
> How can I do the same operation in postgis? I tried with
> sy_intersect, but it takes also the polygons outside my area,
> which simply intersect the border.
> The request I wrote is:
> CREATE TABLE w_md.x
> AS (SELECT area, a.the_geom
> FROM oc a, co b
> WHERE st_intersects(a.the_geom, b.the_geom));
> ALTER TABLE w_md.x_1999 ADD column ggid1 serial;
> ALTER TABLE w_mdi.x_1999 ADD PRIMARY KEY (ggID1);
> Thank you for your help,
> Marta
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2013.0.2805 / Virus Database: 2637/6000 - Release Date: 12/31/12
> Internal Virus Database is out of date.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130114/de062a64/attachment.html>
