[postgis-users] No intersection between two rasters notice
Bborie Park
bkpark at ucdavis.edu
Tue Jan 15 09:26:25 PST 2013
Yes, part of the issue is due to adjacent tiles. If you're using
PostGIS 2.0, add something like...
AND ST_Touches(rast1::geometry, rast2::geometry) != TRUE
If you're running PostGIS from svn...
AND ST_Touches(rast1, rast2) != TRUE
-bborie
On 01/15/2013 08:45 AM, Francois Hugues wrote:
> Hi everyone,
> I'm facing a new difficulty with rasters. This time with
> st_MapAlgebraExpr (the whole query is below). I have this notice when I
> try to cross two rasters with exactly similar tiles.
> NOTICE: The two rasters provided have no intersection. Returning no
> band raster
> To avoid to cross tiles with others where there were effectively no
> intersection I tried the where clause "where st_intersects(rast1,
> rast2)" but the problem is not really solved. Is it because of adjacent
> tiles ?
> Is there a more effective (and faster) way to use mapalgebra and to
> avoid this creation of empty tiles which prevent to use st_convexhull
> (and every function which use convexhull) ?
> Hugues.
> select alti.rid, st_mapalgebraexpr(alti.rast, slopes.rast,
> '[rast1]*[rast2]', '32BF', 'NULL', 'NULL', 'NULL') rast
> from rasters.alti_cons_ign_alpes alti, rasters.slopes_alpes slopes
> where st_intersects(alti.rast, slopes.rast)
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
