[postgis-users] No intersection between two rasters notice
Francois Hugues
hugues.francois at irstea.fr
Wed Jan 16 12:58:53 PST 2013
One more time thank you for the answer Bborie !
Two more details :
1. I didn't know it was possible to use rast::geometry. Is it similar as st_convexhull, st_envelope ?
2. You wrote st_touches != TRUE. Is it the same as ='f'. One is faster than the other ?
Hugues.
-----Message d'origine-----
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Bborie Park
Envoyé : mardi 15 janvier 2013 18:26
À : postgis-users at lists.osgeo.org
Objet : Re: [postgis-users] No intersection between two rasters notice
Yes, part of the issue is due to adjacent tiles. If you're using PostGIS 2.0, add something like...
AND ST_Touches(rast1::geometry, rast2::geometry) != TRUE
If you're running PostGIS from svn...
AND ST_Touches(rast1, rast2) != TRUE
-bborie
On 01/15/2013 08:45 AM, Francois Hugues wrote:
> Hi everyone,
> I'm facing a new difficulty with rasters. This time with
> st_MapAlgebraExpr (the whole query is below). I have this notice when
> I try to cross two rasters with exactly similar tiles.
> NOTICE: The two rasters provided have no intersection. Returning no
> band raster
> To avoid to cross tiles with others where there were effectively no
> intersection I tried the where clause "where st_intersects(rast1,
> rast2)" but the problem is not really solved. Is it because of
> adjacent tiles ?
> Is there a more effective (and faster) way to use mapalgebra and to
> avoid this creation of empty tiles which prevent to use st_convexhull
> (and every function which use convexhull) ?
> Hugues.
> select alti.rid, st_mapalgebraexpr(alti.rast, slopes.rast,
> '[rast1]*[rast2]', '32BF', 'NULL', 'NULL', 'NULL') rast from
> rasters.alti_cons_ign_alpes alti, rasters.slopes_alpes slopes where
> st_intersects(alti.rast, slopes.rast)
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
bkpark at ucdavis.edu
