[postgis-users] No intersection between two rasters notice
Bborie Park
bkpark at ucdavis.edu
Wed Jan 16 13:20:25 PST 2013
1. rast::geometry = ST_ConvexHull(rast).
2. I'd assume so... I'm just used to using boolean TRUE or FALSE.
-bborie
On 01/16/2013 12:58 PM, Francois Hugues wrote:
> One more time thank you for the answer Bborie !
> Two more details :
> 1. I didn't know it was possible to use rast::geometry. Is it similar as st_convexhull, st_envelope ?
> 2. You wrote st_touches != TRUE. Is it the same as ='f'. One is faster than the other ?
> Hugues.
> -----Message d'origine-----
> De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Bborie Park
> Envoyé : mardi 15 janvier 2013 18:26
> À : postgis-users at lists.osgeo.org
> Objet : Re: [postgis-users] No intersection between two rasters notice
> Yes, part of the issue is due to adjacent tiles. If you're using PostGIS 2.0, add something like...
> AND ST_Touches(rast1::geometry, rast2::geometry) != TRUE
> If you're running PostGIS from svn...
> AND ST_Touches(rast1, rast2) != TRUE
> -bborie
> On 01/15/2013 08:45 AM, Francois Hugues wrote:
>> Hi everyone,
>> I'm facing a new difficulty with rasters. This time with
>> st_MapAlgebraExpr (the whole query is below). I have this notice when
>> I try to cross two rasters with exactly similar tiles.
>> NOTICE: The two rasters provided have no intersection. Returning no
>> band raster
>> To avoid to cross tiles with others where there were effectively no
>> intersection I tried the where clause "where st_intersects(rast1,
>> rast2)" but the problem is not really solved. Is it because of
>> adjacent tiles ?
>> Is there a more effective (and faster) way to use mapalgebra and to
>> avoid this creation of empty tiles which prevent to use st_convexhull
>> (and every function which use convexhull) ?
>> Hugues.
>> select alti.rid, st_mapalgebraexpr(alti.rast, slopes.rast,
>> '[rast1]*[rast2]', '32BF', 'NULL', 'NULL', 'NULL') rast from
>> rasters.alti_cons_ign_alpes alti, rasters.slopes_alpes slopes where
>> st_intersects(alti.rast, slopes.rast)
>> postgis-users mailing list
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
