[postgis-users] out-db
LPlateAndy
andy at centremaps.co.uk
Wed Jan 16 09:29:40 PST 2013
I've tried using both the asp and php versions of the BostonGIS minimalist
viewer (added to as php by bborie i note) and keep getting unable to load
image issues even when only trying to render a basic shape as a raster -
i.e. not relying on the data i've loaded
With QuantumGIS (fresh install) i can view the raw image and an in - db
image but the out-db image returns the following fault.
Problem signature:
Problem Event Name: APPCRASH
Application Name: qgis.exe
Application Version: 0.0.0.0
Application Timestamp: 4fdce845
Fault Module Name: MSVCR90.dll
Fault Module Version: 9.0.30729.1
Fault Module Timestamp: 488ef6c5
Exception Code: c0000005
Exception Offset: 0003ab1a
OS Version: 6.1.7601.2.1.0.272.7
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Any ideas?
I have tried running a query in pgAdmin to generate an output file and that
works for the out-db which gives me some reassurance that the data has
loaded ok. The output also drops in size from 10Mb to 2MB when i lower the
quality from 85 to 25 pct which suggests the output isn't just blank. I
don't suppose anyone knows a tool to view byte array data as an image?
Thanks in advance.... Andy
View this message in context: http://postgis.17.n6.nabble.com/out-db-tp5002226p5002307.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
