[postgis-users] out-db
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Jan 21 08:55:50 PST 2013
> With QuantumGIS (fresh install) i can view the raw image and an in - db
> image but the out-db image returns the following fault.
> Problem signature:
> Problem Event Name: APPCRASH
> Application Name: qgis.exe
> Application Version: 0.0.0.0
> Application Timestamp: 4fdce845
> Fault Module Name: MSVCR90.dll
> Fault Module Version: 9.0.30729.1
> Fault Module Timestamp: 488ef6c5
> Exception Code: c0000005
> Exception Offset: 0003ab1a
> OS Version: 6.1.7601.2.1.0.272.7
> Locale ID: 2057
> Additional Information 1: 0a9e
> Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
> Additional Information 3: 0a9e
> Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
> Any ideas?
This is probably because QGIS relies in the GDAL PostGIS Raster Driver to display PostGIS rasters. Probably the driver is returning some kind of error that QGIS isn't able to handle.
Pierre
