[postgis-users] Integer geometry type
Stephen Mather
mather.stephen at gmail.com
Wed Jan 16 20:41:27 PST 2013
Ah, proper compression. Even better. :)
Best,
Steve
On Wed, Jan 16, 2013 at 6:34 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Development work in this vein is ongoing
> https://github.com/pramsey/pointcloud
> On Wed, Jan 16, 2013 at 1:49 PM, Bruce Rindahl <bruce.rindahl at gmail.com>
> wrote:
> > I am currently building a large PostGIS database of lidar data and going
> > through several performance tweaks to make 1.5 billion records respond
> > better. One of the big ones was to convert the z data by multiplying by
> 100
> > and storing it as an integer instead of a double (I know - pretty
> obvious).
> > The resulting reduction in storage space is significant as is query
> > performance. The x and y values are stored as a point value in a
> geometry
> > type which i believe is stored like two double precision values. Would
> it
> > be possible to specify a special geometry type using integer values
> instead
> > of doubles? You could either add a factor (and a special SRID) or just
> > round the values (possible in my case - are the lidar points really
> accurate
> > to less than a foot?). D3.js is doing something very similar to this in
> its
> > topoJSON format.
> > How much brain damage would this cause? Just thinking out loud...
> > Bruce
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130116/1a715888/attachment.html>
