[postgis-users] Integer geometry type
Javier de la Torre jatorre at vizzuality.com
Wed Jan 16 21:56:13 PST 2013
nice Paul!
Javier de la Torre
@jatorre
Vizzuality / CartoDB
148 Lafayette St. PH, New York, 10013,USA
+1 347 320 7715
www.cartodb.com
Map, analyze and build applications with your data
On Jan 16, 2013, at 8:41 PM, Stephen Mather wrote:
> Ah, proper compression.  Even better.  :)
> Best,
> Steve
> On Wed, Jan 16, 2013 at 6:34 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Development work in this vein is ongoing
> https://github.com/pramsey/pointcloud
> On Wed, Jan 16, 2013 at 1:49 PM, Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
> > I am currently building a large PostGIS database of lidar data and going
> > through several performance tweaks to make 1.5 billion records respond
> > better.  One of the big ones was to convert the z data by multiplying by 100
> > and storing it as an integer instead of a double (I know - pretty obvious).
> > The resulting reduction in storage space is significant as is query
> > performance.  The x and y values are stored as a point value in a geometry
> > type which i believe is stored like two double precision values.  Would it
> > be possible to specify a special geometry type using integer values instead
> > of doubles?  You could either add a factor (and a special SRID) or just
> > round the values (possible in my case - are the lidar points really accurate
> > to less than a foot?).  D3.js is doing something very similar to this in its
> > topoJSON format.
> > How much brain damage would this cause?  Just thinking out loud...
> > Bruce
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130116/7718737b/attachment.html>
