[postgis-users] Fwd: Location of nadgrid file
Jan Hartmann
j.l.h.hartmann at uva.nl
Thu Jan 17 06:11:21 PST 2013
Or perhaps the place in the source code that generates the error message:
ERROR: transform: couldn't project point (155000 463000 0): failed to
load datum shift file (-38)
I did several greps on the postgis-2.1.0SVN tree, without any result
-------- Original Message --------
Subject: [postgis-users] Location of nadgrid file
Date: Thu, 17 Jan 2013 14:46:08 +0100
Reply-To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
To: <postgis-users at lists.osgeo.org>
Can anyone tell me where the nadgrids-file, as used by proj4 to apply
grid shifts to a projection, should be installed for postgis? I produced
one, put it in the standard proj installation directory
(/usr/share/proj), and it works from the commandline with cs2cs.
However, when I put an entry in the postgis spatial_ref_sys table for a
new projection with this nadgrids file, the st_transform command says:
"failed to load datum shift file (-38). It also happens when I put in
the whole path. What should I do?
Jan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130117/5b3d3ef9/attachment.html>
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
