[postgis-users] Fwd: Location of nadgrid file
Jan Hartmann
j.l.h.hartmann at uva.nl
Thu Jan 17 06:52:23 PST 2013
That's it. I exported PROJ_DEBUG=5, and restarted the server. In the log
I see a proj error message: "pj_open_lib <path>/test.ntv2 failed",
followed by the PostGIS error message. The location for ntv2-files seems
to be:
<postgresql install dir>/share/contrib/postgis-2.1/proj
So I copied the ntv2 file there, restarted the server again, and the
whole thing works.
Is this a bug? Even when I give an absolute path for the ntv2-file, it
gets appended to the above location. And I would prefer the ntv2 files
to be read from the standard proj installation directory. It's given
with configure, so that shouldn't be a problem. Or should the postgresql
server only have access to its own install dir? In that case, this
should be documented.
Anyway, thanks Howard, for the fast reply.
Jan
On 01/17/2013 03:19 PM, Howard Butler wrote:
> Setting PROJ_DEBUG=ON in the shell environment before starting
> postgres might be instructive.
> On Jan 17, 2013, at 8:11 AM, Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>> wrote:
>> Or perhaps the place in the source code that generates the error message:
>> ERROR: transform: couldn't project point (155000 463000 0): failed
>> to load datum shift file (-38)
>> I did several greps on the postgis-2.1.0SVN tree, without any result
>> -------- Original Message --------
>> Subject: [postgis-users] Location of nadgrid file
>> Date: Thu, 17 Jan 2013 14:46:08 +0100
>> From: Jan Hartmann <j.l.h.hartmann at uva.nl>
>> Reply-To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> To: <postgis-users at lists.osgeo.org>
>> Can anyone tell me where the nadgrids-file, as used by proj4 to apply
>> grid shifts to a projection, should be installed for postgis? I
>> produced one, put it in the standard proj installation directory
>> (/usr/share/proj), and it works from the commandline with cs2cs.
>> However, when I put an entry in the postgis spatial_ref_sys table for
>> a new projection with this nadgrids file, the st_transform command
>> says: "failed to load datum shift file (-38). It also happens when I
>> put in the whole path. What should I do?
>> Jan
>> <Attached Message Part>
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130117/b8b1879a/attachment.html>
