[postgis-users] ST_Buffer returning multipolygons
marquz74 marquz74 at gmail.com
Thu Jan 17 15:41:10 PST 2013
Hi to all,
I'm practicing with ST_buffer on North Carolina Dataset (nc_spm_08).
By running the following query:
SELECT GeometryType(sub.buffer)
FROM (
        SELECT st_buffer (the_geom, 100) AS buffer
        FROM streams
) AS sub
WHERE
        GeometryType(sub.buffer)  <> 'POLYGON';
I've been getting some MULTIPOLYGON records.
Is it possible? I guessed ST_Buffer could return POLYGON geometries only...
was I wrong?
Thanks in advance.
Marco
View this message in context: http://postgis.17.n6.nabble.com/ST-Buffer-returning-multipolygons-tp5002333.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
