[postgis-users] Fwd: Location of nadgrid file
Jan Hartmann
j.l.h.hartmann at uva.nl
Fri Jan 18 06:17:03 PST 2013
On 01/18/2013 03:11 PM, Mark Cave-Ayland wrote:
> Hi Jan,
> The reason that the share/contrib path exists was for the Windows
> Installer - this allows it to bundle a local copy of the grid files
> rather than using a system libproj.dll which may or may not have the
> grid files installed.
> In general, the in-built libproj.dll search path should work as normal
> and use the PostGIS path as a fallback, so it suggests something else
> is amiss.
In my case (a clean, self-compiled Linux version with user defined
installation directories) there seem to be two problems:
- the original proj search-path isn't found
- an absolute path gets appended to the PostGIS path
I'm not sure of the first one, but the second is certainly a bug.
Jan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130118/9c757949/attachment.html>
