[postgis-users] F18: Postgresql 9.2.x/PostGIS 1.5.x issues
Jeff Lake
jeff at michiganwxsystem.com
Sat Jan 26 07:33:10 PST 2013
They probably have been packaged as RPM's yet
if that is the case, You will need to compile from source
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 1/26/2013 10:12, Max Pyziur wrote:
> On Sat, 26 Jan 2013, Devrim GÜNDÜZ wrote:
>> Hi,
>> On Thu, 2013-01-24 at 15:42 -0500, Max Pyziur wrote:
>>>> This is a known issue, and there is already a bugzilla entry about
>>> this. I
>>>> hope to fix it in a few days, by updating GeOS to 3.3.7 and PostGIS
>>> to
>>>> 2.0.2.
>>> I'm sure that there are for more than myself who appreciate these
>>> efforts. Looking forward to the new releases.
>> Pushed updates:
>> https://admin.fedoraproject.org/updates/player-3.0.2-24.fc18,gdal-1.9.1-15.fc18.1,grass-6.4.2-5.fc18,geos-3.3.7-1.fc18,postgis-2.0.2-2.fc18?_csrf_token=f003677623a5c57a7aec5e6a15a0e72ae05f17db
>> If you have a chance go test the packages, please do. They will be
>> available in the next 7 days or so, unless 2 people give +1 before then.
> I've tried finding the packages in the following way:
> yum --enablerepo=updates-testing update gd\* postg\* geos\* gras\*
> None of the versions of these packages appear.
> Is there an alternative way of getting them and installing them?
>> Regards,
> Thanks.
> Max Pyziur
> pyz at brama.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130126/7ac89da4/attachment.html>
