[postgis-users] F18: Postgresql 9.2.x/PostGIS 1.5.x issues
Max Pyziur
pyz at brama.com
Sat Jan 26 08:28:50 PST 2013
On Sat, 26 Jan 2013, Jeff Lake wrote:
> They probably have been packaged as RPM's yet
> if that is the case, You will need to compile from source
Sorry, but that isn't what the message says. They have been packaged into
RPMs and placed into a testing repository. The question is which testing
repository, since a standard yum command can't retrieve these RPMs.
This is particularly frustrating, since F18 was released with Postgresql
9.2.x, and PostGIS 1.5.x, the latter not being able to function with the
former.
If you had data and projects running on F17 on Postgresql 9.1.x and
PostGIS 1.5.x, and accepted a default upgrade from F17 to F18, you would
be seriously stuck.
As it is, I have three machines, only one of which that I've migrated to
F18 from F17.
So, I'm not that stuck.
But I would like to know where the testing RPMs are so that my data and
projects are current across the three machines.
> Jeff Lake
> MichiganWxSystem
> AllisonHouse
> GRLevelXStuff
Max Pyziur
pyz at brama.com
> On 1/26/2013 10:12, Max Pyziur wrote:
> On Sat, 26 Jan 2013, Devrim GÜNDÜZ wrote:
> Hi,
> On Thu, 2013-01-24 at 15:42 -0500, Max Pyziur wrote:
> This is a known issue, and there is already a bugzilla entry about
> this. I
> hope to fix it in a few days, by updating GeOS to 3.3.7 and PostGIS
> to
> 2.0.2.
> I'm sure that there are for more than myself who appreciate these
> efforts. Looking forward to the new releases.
> Pushed updates:
> https://admin.fedoraproject.org/updates/player-3.0.2-24.fc18,gdal-1.9.1-15.fc18.1,grass-6.4.2-5.fc18,geos-3.3.7-1.fc18,postgis-2.0.2-2.fc18?_csrf_token=f003677623a5c57a7aec5e6
> a15a0e72ae05f17db
> If you have a chance go test the packages, please do. They will be
> available in the next 7 days or so, unless 2 people give +1 before then.
> I've tried finding the packages in the following way:
> yum --enablerepo=updates-testing update gd\* postg\* geos\* gras\*
> None of the versions of these packages appear.
> Is there an alternative way of getting them and installing them?
> Regards,
> Thanks.
> Max Pyziur
> pyz at brama.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
