[postgis-users] F18: Postgresql 9.2.x/PostGIS 1.5.x issues
Jeff Lake jeff at michiganwxsystem.com
Sat Jan 26 08:39:45 PST 2013
If you will read ...
where does it mention that they have been packaged as RPM's
it DOESN'T
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 1/26/2013 11:28, Max Pyziur wrote:
> On Sat, 26 Jan 2013, Jeff Lake wrote:
>> They probably have been packaged as RPM's yet
>> if that is the case, You will need to compile from source
> Sorry, but that isn't what the message says. They have been packaged
> into RPMs and placed into a testing repository. The question is which
> testing repository, since a standard yum command can't retrieve these
> RPMs.
> This is particularly frustrating, since F18 was released with
> Postgresql 9.2.x, and PostGIS 1.5.x, the latter not being able to
> function with the former.
> If you had data and projects running on F17 on Postgresql 9.1.x and
> PostGIS 1.5.x, and accepted a default upgrade from F17 to F18, you
> would be seriously stuck.
> As it is, I have three machines, only one of which that I've migrated
> to F18 from F17.
> So, I'm not that stuck.
> But I would like to know where the testing RPMs are so that my data
> and projects are current across the three machines.
>> Jeff Lake
>> MichiganWxSystem
>> AllisonHouse
>> GRLevelXStuff
> Max Pyziur
> pyz at brama.com
>> On 1/26/2013 10:12, Max Pyziur wrote:
>>       On Sat, 26 Jan 2013, Devrim GÜNDÜZ wrote:
>>             Hi,
>>             On Thu, 2013-01-24 at 15:42 -0500, Max Pyziur wrote:
>>                         This is a known issue, and there is already a
>> bugzilla entry about
>>                   this. I
>>                         hope to fix it in a few days,  by updating
>> GeOS to 3.3.7 and PostGIS
>>                   to
>>                         2.0.2.
>>                   I'm sure that there are for more than myself who
>> appreciate these
>>                   efforts. Looking forward to the new releases.
>>             Pushed updates:
>> https://admin.fedoraproject.org/updates/player-3.0.2-24.fc18,gdal-1.9.1-15.fc18.1,grass-6.4.2-5.fc18,geos-3.3.7-1.fc18,postgis-2.0.2-2.fc18?_csrf_token=f003677623a5c57a7aec5e6
>>             a15a0e72ae05f17db
>>             If you have a chance go test the packages, please do.
>> They will be
>>             available in the next 7 days or so, unless 2 people give
>> +1 before then.
>>       I've tried finding the packages in the following way:
>>       yum --enablerepo=updates-testing update gd\* postg\* geos\* gras\*
>>       None of the versions of these packages appear.
>>       Is there an alternative way of getting them and installing them?
>>             Regards,
>>       Thanks.
>>       Max Pyziur
>>       pyz at brama.com
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130126/a6b565c4/attachment.html>
