[postgis-users] F18: Postgresql 9.2.x/PostGIS 1.5.x issues
Max Pyziur pyz at brama.com
Sat Jan 26 12:30:58 PST 2013
On Sat, 26 Jan 2013, Devrim GÜNDÜZ wrote:
> Hi,
> On Thu, 2013-01-24 at 15:42 -0500, Max Pyziur wrote:
>>> This is a known issue, and there is already a bugzilla entry about
>> this. I
>>> hope to fix it in a few days,  by updating GeOS to 3.3.7 and PostGIS
>> to
>>> 2.0.2.
>> I'm sure that there are for more than myself who appreciate these
>> efforts. Looking forward to the new releases.
> Pushed updates:
> https://admin.fedoraproject.org/updates/player-3.0.2-24.fc18,gdal-1.9.1-15.fc18.1,grass-6.4.2-5.fc18,geos-3.3.7-1.fc18,postgis-2.0.2-2.fc18?_csrf_token=f003677623a5c57a7aec5e6a15a0e72ae05f17db
I see that you provide
postgis
postgis-docs
postgis-utils
at http://koji.fedoraproject.org/koji/buildinfo?buildID=380648
Who provides postgis-jdbc? That needs to be aligned w/ postgis 2.x in
order to use F18, postgresql 9.2.x, etc.
In particular, OpenJUMP (Open Java Map Program - a desktop mapping
application) will not work w/o the postgis-jdbc component.
fyi,
Max Pyziur
pyz at brama.com
> If you have a chance go test the packages, please do. They will be
> available in the next 7 days or so, unless 2 people give +1 before then.
> Regards,
