[postgis-users] F18: Postgresql 9.2.x/PostGIS 1.5.x issues
Max Pyziur pyz at brama.com
Sat Jan 26 09:43:22 PST 2013
On Sat, 26 Jan 2013, Reindl Harald wrote:
> Am 26.01.2013 17:28, schrieb Max Pyziur:
>> On Sat, 26 Jan 2013, Jeff Lake wrote:
>>> They probably have been packaged as RPM's yet
>>> if that is the case, You will need to compile from source
>> Sorry, but that isn't what the message says. They have been packaged into RPMs and placed into a testing
>> repository. The question is which testing repository, since a standard yum command can't retrieve these RPMs
> what is a "standard yum command" for you?
> sorry but you should be specific which such things!
> for me it is "yum clean metadata && yum --enablerepo=updates-testing upgrade"
> or "yum --enablerepo=updates-testing update package1 package2..."
yum --enablerepo=updates-testing update gd\* postg\* geos\* gras\*
is the command that I used, 24 hours after the announcement.
fyi,
Max Pyziur
pyz at brama.com
