[postgis-users] How to Import ESRI Geodatabase format .gdb created by ArcGIS 9.3.1?
charlie
carowan at yahoo.com
Sat Jan 26 13:47:32 PST 2013
I downloaded a large 1.5G file saved in the ESRI Geodatabase format ( .gdb -Not the ESRI Personal Geodatabase, which is supported) that I am looking to import into a PostGIS database. According to the metadata, ArcGIS 9.3.1 was used to create the .gdb database.
I checked both:
ogr2ogr
http://www.gdal.org/ogr2ogr.html
and
http://www.gdal.org/ogr/drv_filegdb.html, which offers a solution, but only for ArcGIS versions 10.0 and above.
Is anyone aware of a utility or solution that supports importing a ESRI Geodatabase created by ArcGIS 9.3.1?
Thanks in advance for any and all advice!
Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130126/1f65bd32/attachment.html>
