[postgis-users] How to Import ESRI Geodatabase format .gdb created by ArcGIS 9.3.1?
Stephen V. Mather
svm at clevelandmetroparks.com
Sat Jan 26 13:56:38 PST 2013
AFAI know, all 9.x FGDBs are a locked inaccessible format to all without ArcGIS license. Problem fixed with 10.x w/ release of a library, but no help for 9.x trapped data.
Best,
Steve Mather
On Jan 26, 2013, at 4:47 PM, "charlie" <carowan at yahoo.com<mailto:carowan at yahoo.com>> wrote:
I downloaded a large 1.5G file saved in the ESRI Geodatabase format ( .gdb -Not the ESRI Personal Geodatabase, which is supported) that I am looking to import into a PostGIS database. According to the metadata, ArcGIS 9.3.1 was used to create the .gdb database.
I checked both:
ogr2ogr
http://www.gdal.org/ogr2ogr.html
and
http://www.gdal.org/ogr/drv_filegdb.html, which offers a solution, but only for ArcGIS versions 10.0 and above.
Is anyone aware of a utility or solution that supports importing a ESRI Geodatabase created by ArcGIS 9.3.1?
Thanks in advance for any and all advice!
Charlie
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130126/954ea9e1/attachment.html>
