[postgis-users] PostGIS Trigger doesn't work
Ralf Suhr
Ralf.Suhr at itc-halle.de
Mon Jan 28 09:29:59 PST 2013
Hi Marcello,
your trigger is fired before any data is in table "adutoras".
CREATE OR REPLACE FUNCTION topology_fields()
RETURNS trigger AS
BEGIN
SELECT string_agg(municipios.nome,', ')
INTO NEW.municipios_abastecidos
FROM municipios
WHERE ST_Intersects(NEW.geom, municipios.geom);
RETURN NEW;
END;
LANGUAGE 'plpgsql';
Gr
Ralf
On Montag 28 Januar 2013 16:11:35 Marcello Benigno wrote:
Hello All,
The trigger below don't works and I need that when a new pipeline
(adutoras) is inserted or updated, the procedure check what are the
municipalities (municipios) that intersects the pipes and put the names of
the municipalities inside the field "municipios_abastecidos".
RETURNS "trigger" AS$$BEGIN
NEW.municipios_abastecidos:=(
FROM municipios, adutoras
WHERE ST_Intersects(adutoras.geom, municipios.geom)
AND adutoras.gid = NEW.gid
);RETURN NEW;END; $$
LANGUAGE 'plpgsql';
CREATE TRIGGER fill_topology_fields
BEFORE INSERT OR UPDATE ON adutorasFOR EACH ROW EXECUTE PROCEDURE
topology_fields();
Thanks in advance,
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130128/6855d82a/attachment.html>
